- 22 Mar 2009
Thanks for your honest review stulid, I would avoid ivybridge if I were u. I knew it will come to poor overclocking chip. Glad I stick to my i7 2600K at 5GHz at 1.38v.
Could just be a **** chip?
And after owning a 2500K that was 5Ghz+ (ran SuperPI at 5.2Ghz), could have gone higher if was a brave man with the Vcore.
I guess I was expecting the same.
So if you had the choice which would you go for in my position, I have a z77 board all ready, 2500k or 3570k?
Honestly, I want my 2500K back.
What kinda temps are you pulling currently at 4.6Ghz Stulid? isn't 1.35v and 4.6Ghz still with in the "reasonable" tempratures for IB?
Im correct in understand that the kuhler performs just a bit better than high end air cooling correct? I say a bit I mean like 10-20% cooler kind of idea?
Ah so the Phanteks/K2 out does closed loop water cooling?
