£1860 - spec me please
18 Mar 2012
Hi guys,
I asked for help building a gaming rig a few months ago and was advised to wait it out for Ivy Bridge. I'm now looking to make my purchase within the next 2 days.
I'll be needing a monitor (23/24") for gaming (that I can also hook my PS3 upto). And most importantly the best quality rig I can afford (It's primarily for gaming).
I already have a keyboard, mouse and speakers.
Budget £1860
Thank you very much in advance.
Hi beejjacobs
Thanks for your help :) Would that spec play the latest games on ultra settings? (Sorry I'm not very savvy in this department)
Also, would you recommend I overclocked it or is that too complicated? What is the benefit of overclocking?
Thanks
Hi beejjacobs
Thanks
yes i would overclock it if u feel ok to do it.
and it should play lastest games on ultra.
680 best GPU around. I always go for custom cooling solutions, like the Twin Frozrs, Sapphire dual fans.
2500K 3570K best gaming CPUs around.
750 / 850W for SLI support.
8GB 12800C9 perfect for gaming.
big CPU quiet cooler for overclocking. Can go cheaper, I would aim at sweet spot 4.4GHz overclocking.
SSD for OS and games.
120Hz screen for smooth gaming.
Good motherboard for overclocking and SLI. Can go cheaper (I like the AsRock Z68 Extreme 4, like mine).
So yeah, that's the kind of stuff you want for gaming.
Case is OK but plenty of choice around. If looks no object, the Raven RV03 is a good air cooling case for quietness and performance. Can Go Carbide 500D, Obsidian 550D, or plenty of others.
Can go 128GB M4, but you will have to manage space better (games around 10-15GB nowadays).
Thanks Stinger53.
Thanks olivier renault, that's massively helpful.
Can I just ask would it be worth buying the the benq xl2420t over the benq xl2410t? Or isn't there much difference.
Hi beejjacobs
Thanks
My mate Beej has done a very nice spec for you there. Unfortunately everyone has gone mad today ordering the new kit so you will find a lot of the good mobos are now out of stock i.e what Beej spec'd. Gives you an idea of what's possible for the cash though.
I try to explain overclocking with cars. Now you can buy very fast and expensive cars but they are limited electronically to 155mph even though they can go much faster.
The K edition CPUs are "engines" without the limiter, so you can manually tell it what it is. You could get 4ghz from the sandybridge i5Ks on the stock cooler and with a better heatsink 4.4 was easily attainable....not bad from a 3.3 CPU. Asking it to run faster increases temps which is why people add the aftermarket coolers.
The speed is the FSB multiplied by the CPUs multiplier/ratio. Overclocking these K CPUs is as simple as upping the multiplier or ratio. Infact many mobos have an auto option to make it even easier for you. Each CPU is unique, we call it the silicon lottery. Some CPUs can run faster than others, you just dont know till you try, with sandybridge having been out for sometime we know 4.4 is a good expected overclock. You will see threads start up soon with people showing how far they have "pushed" their unlocked ivybridge CPUs.
If you have any more questions or need help come build day, come back and find us we are more than willing to baby step you through the process :)
FSB hasn't existed since LGA 1366. :p
haha well spotted mate, it's been a long day.... I meant CPU base clock. I'm old school and old habits die hard ;)
Same difference though, the base clock (100mhz) X the multiplier/ratio (34) = speed 3400mhz or 3.4Ghz. As you up the multiplier by one it's easy to calculate the increase in speed. So 35 is 3.5Ghz, 36 3.6Ghz and so on. There are tools or software rather that we use to test stability but we can cover this later once you have the machine setup nicely at stock speeds.
Sorry for any confusion caused...a slip of the tongue is no fault of the mind and all that jazz lol
Your basket
Product Name Qty Price Line Total
EVGA GeForce GTX 680 2048MB GDDR5 PCI-Express Graphics Card (02G-P4-2680-KR) £429.95
(£358.29) £859.90
(£716.58)
Intel Core i7-3820 3.60GHz (Sandybridge-E) Socket LGA2011 Processor - Retail £219.95
(£183.29) £219.95
(£183.29)
BenQ G2750 27" Widescreen LCD Monitor - Black £179.99
(£149.99) £179.99
(£149.99)
Asrock X79 Extreme 4 Intel X79 (Socket 2011) DDR3 Motherboard £150.00
(£125.00) £150.00
(£125.00)
OCZ ZX Series 850W '80 Plus Gold' Modular Power Supply £124.99
(£104.16) £124.99
(£104.16)
Corsair Vengeance Blue 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual/Quad Channel Kit (CMZ16GX3M4A1600C9B) £89.99
(£74.99) £89.99
(£74.99)
Noctua NH-D14-2011 Dual Radiator CPU Cooler with PWM Fans (Socket LGA2011) £72.98
(£60.82) £72.98
(£60.82)
Western Digital Caviar Green 1TB SATA 6Gb/s 32MB Cache - OEM (WD10EARX) £69.98
(£58.32) £69.98
(£58.32)
OCZ Petrol 64GB 2.5" SATA-3 Solid State Hard Drive (PTL1-25SAT3-64G) £59.99
(£49.99) £59.99
(£49.99)
Cooler Master HAF 912 Case - Black £52.99
(£44.16) £52.99
(£44.16)
Sub Total : £1,567.30
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £14.75
VAT is being charged at 20.00% VAT : £316.41
Total : £1,898.46
£40 over budget BUT you get SLI GTX680 AND a 27'' screen
Thanks Stinger53.
The xl2420t has the latest Nvidia 3D Vision 2 where as the xl2410t has the original.
Newer tech etc...
I have my eye on the xl2420t
Hmm, even when it's dumbed down for me I still find it difficult to understand. Thank you for trying to explain that to me.
Would it be worth waiting for the GTX 690? Or will that be out of my price range?
My money would be on something around this.
YOUR BASKET
1 x Palit GeForce GTX 680 Jetstream 2048MB GDDR5 PCI-Express Graphics Card £479.99
1 x Crucial RealSSD M4 256GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT256M4SSD2) £189.95
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x IIyama Prolite E2473HDS 24" Widescreen LED Monitor - Black £149.99
1 x Silverstone Strider 1200W Modular '80 Plus Gold' Power Supply ** PRE ORDER PRICE ** (SST-ST1200-G) £149.99
1 x Asrock Z77 Extreme4 Intel Z77 (Socket 1155) DDR3 Motherboard £124.99
1 x Silverstone Raven 3 Full Tower Windowed Case - Black/Gold (SST-RV03B-W USB 3.0) £99.98
1 x Seagate Barracuda Green 2TB SATA 6Gb/s Hard Drive - OEM (ST2000DL003) £93.98
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £72.00
1 x Alpenföhn K2 Mount Doom CPU Cooler (Socket LGA1156/1155/1366/AM2/AM2+/AM3/AM3+/FM1) £64.99
1 x Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9) £39.95
1 x LG GH22NS90 24x DVD±RW SATA ReWriter (Black) - OEM £18.98
Total : £1,688.90 (includes shipping : £20.10).
PSU, not sure. I really like the Strider 1200W, but it's rather overkill, however it's fully modular, gold, not that expensive (same as a Corsair AX850) and fits in the case. XFX 850 XXX would be enough. Hell, even a CM Silent Pro 600 for £55 will do the job.
Monitor, well, can always go BenQ 2420T, or two monitors, i7 ivy, audio card, or a posh case (FT02). Or just save your monies.
YOUR BASKET
This looks great. Thank you very much.
Can I just ask will the BenQ 2420T hook up to the PS3 too?
