***Official GTX 670 thread***
Caporegime
6 Dec 2005
Birmingham
Review listings
Vortez (by our beloved don W3bbo) - http://goo.gl/4NxaF
AnandTech - http://goo.gl/VXTrT
PC Perspective - http://goo.gl/ESiVU
Hot Hardware - http://goo.gl/Xt1aH
Tom's Hardware - http://goo.gl/dtAMc
Hexus - http://goo.gl/8yDmJ
Tech Report - http://goo.gl/ShNB5
Guru3D - http://goo.gl/Yp3Nf
Guru3D 2 & 3 way SLI - http://goo.gl/ZxarN
Guru3D Palit JetStream - http://goo.gl/IJwKr
Guru3D Asus DirectCU II TOP - http://goo.gl/1wVge
HardOCP - http://goo.gl/JIlMR
techPowerUp! - http://goo.gl/w3CI8
TPU Zotac AMP - http://goo.gl/SjX8V
TPU Asus DirectCU II TOP - http://goo.gl/4gKpB
TPU Pailt JetStream - http://goo.gl/60W82
TweakTown - http://goo.gl/fnM7A
Legit Reviews - http://goo.gl/La6qO
bit-tech - http://goo.gl/7T1P2
Hardware Canucks - http://goo.gl/M7ljU
Here's what we know so far.
Release date - 10th May.
Reference specs
Overclocked version specs (e.g. Gigabyte Windforce OC)
Afterburner graph showing extra core boost when overclocked
Pictures
Reference cards
As many of you know already the reference card will use a shorter pcb, as seen on this POV card.
Overclocked / non-reference cards
Pictures of the Gigabyte Windforce 3X OC
It's my opinion that all OC cards will probably use the GTX 680 pcb, there might be a few with the shorter pcb using non-reference coolers but I doubt they will be pre-overclocked. But you never know.
Prices
Obviously no confirmed prices yet. But as Gibbo has said they'll be over £300. I've seen a few Euro prices & UK ones, so I expect some retailer at launch to have the Gigabyte Windforce 3X OC at £370 top price. Between £340 to £370 at launch for OC'd cards. Reference cards I think will be £310 at minimum, Palit, POV cards etc. I'd be shocked if there was any under £300 at launch, but it would be crushing for ATI and a superb move from Nvidia. As usual expect prices to flatten after a couple of weeks, and maybe we'll see something under £300 then.
Performance
TweakTown preview numbers
Performance results from OCN member Martyr82 - clicky
Stock 3D Mark11 results
3D Mark 11 score - http://3dmark.com/3dm11/3353787;jsessionid=1c5mdgwq1bws9cfb09i2khsuv
Code:
Graphics Score - 9598
http://3dmark.com/3dm11/3354519;jsessionid=1i7qj50zh7mt7lbfw8vqukfag
Code:
Graphics Score - 9584
Overclocked 3D Mark 11 score, with extra 165mhz on core and 550 on memory.
http://3dmark.com/3dm11/3355178
Code:
Graphics score - 11125
His GPU-Z validation - http://www.techpowerup.com/gpuz/4zcs5/
Unigine Heaven Benchmark (on these settings)
Some more Gigabyte Windforce 3X OC pictures.
Gigabyte Windforce 3X OC SLI performance
3D Mark 11 - Graphics score 18131
http://3dmark.com/3dm11/3362501;jsessionid=1eyswnu7c5xmtpwmh6fd952a1
Unigine - 2348
**same OCN settings as in OP**
Gigabyte Windforce 3X OC SLI performance with extra overclocking
3D Mark 11 - Graphics score 20027
http://3dmark.com/3dm11/3362774;jsessionid=1ww5suq7uscqq1id6qgoap9k2r
Unigine - 2589
Overclocking for Unigine benchmark (+127 on core & +319 on memory)
Wait they overclock to 1350 Mhz?????
I was reading the turboboost speed of 980 Mhz as the overclocks that people were managing on them!
The reference card start at 915mhz and boosts up to 980mhz. That Gigabyte card starts at 980mhz, then overclock that a bit and the boost on top.
So that guy adding 100mhz onto his core taking it to 1080mhz and then the boost has taken it even further.
From what I can tell, you get almost the same default performance and less power consumption for £120 less.
The only reason, it seems, to spend the £120 more is if you want to overvolt and overclock heavily.
Would be nice to know from Gibbo when the NDA ends, if he can put them up straight away at 00:01 on Thursday morning.
Then we can be disappointed by inflated prices before we go to sleep and not when we wake up to start the day. ;)
The above was a joke, don't hurt me sales and purchasing team.
I'll be swapping out my 590 for a few 4gb version (pretty sure there are 4gb versions), then its nvidia surround time :D
I thought Gibbo said they would be over £300, Though not a lot over was how I read it, Still knowing Nvidia and their pricing structure we could see them around £350-£370. Would be interested to see how close these are to gtx 680 performance, Not sure how convinced I am of Tweaktown`s review as yet.
I do think the gtx670 will shake up the gfx market a bit in terms of pricing, If it does come out just over the £300 mark as the 7970 & 7950 will drop for sure and also the gtx580 should drop to a nice price too.....Hopefully!!
310 i'm getting one. If higher i'll either pass or wait until they are 310. This generation are still overpriced.
btw, the 580 is eol, don't expect huge discounts, just expect them to slowly fade away.
I can see it coming in around 320 quid for reference cards and around 350 quid for non reference cards. Looks like a great card, very close to the 680. Should shake up prices a little hopefully, I just wish nvidia would release the 660 to compete with the 7850/7870 as it seems they have let and have a free run at the mid range so far :-(
Why buy a more expensive 680 now? the 670 is a lot cheaper and performs within a few percent of it, a modest overclock should easily surpass 680 performance.
The MSI GTX670 OC will have a core clock of 965mhz / boost: 1045mhz
Looking at the picture and the other pictures of the MSI card that are around, it does look like this one is a reference pcb & cooler. I'm guessing MSI will release a more overclocked non reference card as well.
Even so I would take the cash saving over a few FPS gained going with a 680. If all you do is bench 3Dmark all day then yeah I suppose the 680 makes sense over a 670, for gaming a 670 would be my choice if it comes in at around £320.
I hope we get some 680 sized 670 PCB's at under 350, not keen on the midget PCB.
If the performance is that close i think i'll change my 680 pre order to a 670 and save nearly £100, also cheaper to go sli in future and similar perf. But we'll see until more reviews are out. Although if these figures are true and 670 is a lot cheaper surely itwill hurt 680 sales... wonder if nvidia really want that to happen which makes me doubt these early previews...
hmm
Very excited to see what these bring to the table, especially if that +1300mhz boost is easily gained on the cards.
Really hope to see some better reviews than the TT one before Thursday.
680 SLI or 670 SLI, its going to be a tough week :o
I know this is a 670 thread but is there any news on overvolting reference 680's yet? Ive pushed the highest i could go on stock volts 0.988v i believe and would love to go higher now that its watercooled.
