- 11 May 2007
- Surrey
Really? The CPU is well within the thermal limits. Now if the back of his case was 80 degrees he might have issues. Apple have designed the iMac to handle prolonged running at temperature. Not a little bit of gaming but day in, day out video, audio and photo editing pushing the CPU and GPU to the limit.
What I don't get is this heat is vented (partially) via the aluminium at the back. Why would that being warm be even a concern to the OP? It's obvious to even people without CompSci degrees that an all-in-one like the iMac is going to get warm in places under load.
It's a giant heatsink, of course it gets hot! 80degrees is well within the thermal limits.
It is an all in one, of course it doesn't dissipate heat as effectively as a gaming PC with loads of space and fans!
Basically you bought it because you thought it'd be really cool, not because of what it is, and now you regret wasting your money. I agree with the poster above.
Yeah to be honest the more i think about it it doesn't seem too bad considering the design etc. I was just coming in from the angle of what happened to my MBP, but that may have been a one-off tbh.
I went ahead and bought an iMac because of the fact that I thought it would be a good replacement for my current computer even though the specifications are more a less identical, I thought because I have used Macs in the past (MBP's, Mac Minis) that it would be a good step up, they use applications that I really enjoy such as: Transmit, Coda, Final cut, xCode, Unison and so on, I thought it would be great for me to buy one and then have one around incase I wanted to use these programs, obviously it was a mistake buying this machine.
I do a web/programming degree, hence the need to go ahead and buy one of these machines, now granted, I could do my work for the most part on dreamweaver/notepad & filezilla, but they are not my preferred apps.
and as there have been a lot of revisions of the iMac, and the design also follows through their displays and portables now I wouldn't see it as a fault when they all behave in a similar fashion.
Apple are **** at admitting there are faults with stuff yes, but it wouldnt have taken them this long. I'd stick with it if you can. Though with you wanting to game I'm surprised you only went with the 512MB card I have to say!![]()
MacBook case cracking is a great one. We'll replace your top case but if your screen bezel is cracked too that's your fault. -_-
The interesting thing I always found about that was they said they had redesigned these top cases with a different material to prevent the issue, but there are people who are on their 3rd or 4th top case.
This
The iMac takes advantage of the huge aluminium back to use it as a heat sink and radiate the excess heat.
It will get hot to the touch. Stop thinking its a PC and start thinking its like a mac. Until it actually shuts down because it's too hot you have nothing to worry about
Pointless thread. The tempartures are fine and well within design parameters.
