** Weekend Deals - ROUND 3 - MEMORY **
Status
Not open for further replies.
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Get your new memory kits now at amazing pricing.
Kingston HyperX Genesis 32GB (8x4GB) DDR3 PC3-12800C9 1600MHz Quad Channel Kit @ £164.99 inc VAT
Kingston's KHX1600C9D3K8/32GX is a kit of eight 512M x 64- bit (4GB) DDR3-1600 CL9 SDRAM (Synchronous DRAM) 2Rx8 memory modules, based on sixteen 256M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 32GB. Each module kit has been tested to run at DDR3-1600 at a low latency timing of 9-9-9 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333 timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V. The JEDEC standard electrical and mechanical specifications
are as follows:
Features:-
- Model Name: KHX1600C9D3K8/32GX
- Main Board: INTEL
- System: DESKTOP
- System Type: DDR3
- M/B Chipset: INTEL P67, INTEL X68, INTEL Z77, INTEL X79
- CAS Latency: 9-9-9-24 2N
- Capacity: 32GB (4GBx8)
- Speed: DDR3-1600 (PC3-12800)
- Test Voltage: 1.50-1.60V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 240-pin DIMM
- Warranty: Lifetime
Was £174.99 Inc. VAT
Only £164.99 inc VAT.
ORDER NOW
Corsair Vengeance Gold 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9G) @ £41.99 inc VAT
Serious about PC memory? So are we.
Like the legendary Dominator, enthusiast-grade Vengeance DRAM is designed for stability, stringently factory-tested, and backed by our limited lifetime warranty. And, we know that great looks are as important as great performance. This is why Vengeance modules come in a variety of colours to match your components and let you build your system just the way you want it.
Overclocking your components can be a fun and rewarding way of pushing your gaming PC to its performance limits. Vengeance can help make this happen. Before each module is assembled, the DRAM chips are individually screened not only to ensure reliable meeting performance specifications, but to allow generous headroom for stable overclocking.
Optimized for Compatibility with the Latest CPUs and Motherboards, Vengeance memory is designed specifically for the latest CPUs. Vengeance modules are available in 1.5V and 1.35V configurations for maximum compatibility with all Intel® Core™ i3, i5 and i7 processors, as well as the 2nd generation Intel Core processor family. With dual channel, triple channel, and quad channel kits, there's a Vengeance configuration that's perfect for your motherboard.
XMP Memory Profile for simple, safe overclocking, Vengeance memory supports the Intel XMP (Extreme Memory Profile) standard, and each module is individually factory-programmed with an XMP profile indicating supported timing, frequency and voltages. Just enable XMP on your compatible motherboard and you'll automatically get optimized memory overclocking without having to deal with multiple BIOS settings. Of course, if you're an experienced overclocker - or an aspiring one - you can adjust the settings to push for even higher performance.
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.35V for motherboards using AMD, Intel First and second Generation Core processors dual channel platforms. Vengeance memory modules provide users with outstanding memory performance and stability with loads of overclocking headroom. Vengeance Each module is built using carefully selected DRAM to allow for the best performance and a limited lifetime warranty.
- 8GB (2x4GB) DDR3 for AMD, Intel Dual processors
- 1600MHz
- 9-9-9-24 latency
- Voltage: 1.35V
- Vengeance Military Green heat spreader for styling and performance
- Intel XMP (Extreme Memory Profile) Support
- Limited Lifetime Warranty
- Compatible with Sandybridge and Ivybridge
Was £49.99 Inc. VAT
Only £41.99 inc VAT.
ORDER NOW
Kingston HyperX RED Limited Edition 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3B1RK2/8GX) @ £35.99 inc VAT
Kingston’s HyperX® Red Limited Edition is specially designed to enhance high-performance systems. It features a sleek and aggressive look to complement any compatible motherboard and desktop computer. HyperX Red Limited Edition is available in 4GB single modules or 8GB kits. It comes in speeds of 1333MHz and 1600MHz and voltages of 1.5V and 1.65V to meet the demands of gamers, enthusiasts, system builders and consumers looking for high-performance upgrades.
HyperX Red memory modules have been maximised for optimal heat dissipation. In addition, the 1600 MHz 8GB kits are fully XMP-ready to enable easy overclocking for optimum performance. All HyperX memory products come with a lifetime warranty, free technical support and legendary Kingston® reliability
Model Name: KHX1600C9D3X2K2/8GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
CAS Latency: 9-9-9-27 2N
Capacity: 8GB (4GBx2)
Test Voltage: 1.50-1.65V
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Warranty: Lifetime
Was £44.98[OLDPRICE] Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
Samsung Green 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual Channel Kit (MV-3V4G3D/US) @ £39.95 inc VAT
nonl2br
These Samsung Green kits are a world first using 30nm technology. This results in lower power usage, extended life and ultra low profile making them compatible with all DDR3 solutions including small form factor.<br/><br/>
Boost performance with Samsung genuine PC memory. As the number one memory supplier in the world, Samsung DRAM modules are made with 100% Samsung components. With the 30nm-Class DDR3 1600MHz Extreme Low Voltage UDIMM module from Samsung, you can get faster speed and greater reliability from your computer while consuming less energy. Use Samsung UDIMM DDR3 memory to replace or increase the memory in your desktop or server. This Samsung DDR3 memory module employs 30-nanometer technology and, as a result, uses up to 65 percent less power and is only two-thirds the size of conventional 60-nanometer memory modules. This version of Samsung DDR3 has a 8 GB capacity (2 DRAM modules, each with 4 GB). <br/><br/>
The other major advantage of these modules is their overclocking ability, in our own testing we achieved 2400MHz with CAS 11-11-11-28-1T timings with just 1.55v resulting in staggering levels of performance.
<br/><br/>
<strong>Features:-</strong><br/><br/>
- Model Name: MV-3V4G3D/US<br/>
- Main Board: INTEL/AMD<br/>
- System: DESKTOP/SFF<br/>
- System Type: DDR3<br/>
- M/B Chipset: INTEL P67, Z68, Z77, X79 & AMD Chipsets<br/>
- CAS Latency: 11-11-11-28 1N<br/>
- Capacity: 8GB (4GBx2)<br/>
- Speed: DDR3-1600 (PC3-12800)<br/>
- Test Voltage: 1.25-1.55V<br/>
- Registered/Unbuffered: Unbuffered<br/>
- Error Checking: Non-ECC<br/>
- Type: 240-pin DIMM Low Profile<br/>
- Warranty: Lifetime<br/>
<br/><br/>
<strong>
Overclocking Features (Not Guaranteed)</strong><br/><br/>
- 1600MHz (7-8-8-24 1N) @ 1.40v<br/>
- 1866MHz (9-9-9-27 1N) @ 1.40v<br/>
- 2000MHz (9-10-10-28 1N) @ 1.45v<br/>
- 2133MHz (10-10-10-28 1N) @ 1.45v<br/>
- 2400MHz (11-11-11-28 2N) @ 1.50v<br/>
- In our own in house testing we were able to achieve all the above clock speeds on an Asus X79 platform with 4x4GB modules (16GB total) SuperPI Stable too, 32M<br/>
Was £49.99 Inc. VAT
Only £39.95 inc VAT.
ORDER NOW
Corsair Value 8GB (2x4GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit (CMV8GX3M2A1333C9) @ £32.99 inc VAT
Corsair built its reputation on performance memory that shines in the most demanding computing situations: extreme gaming and high-transaction processing environments. But not all computers are put to such extreme usage. So we brought the same reliability, testing and Corsair quality to a line of memory designed to support standard computing situations such as popular office applications. Now it's one of our most popular memory lines. Backed with a lifetime warranty, it is memory you can rely on.
Density: 8GB Kit (2x4GB)
Speed: 1333MHz
Timing: 9-9-9-24
Type: DDR3
Format: DIMM
Pin Out: 240 Pin
Voltage: 1.5V
Warranty: 10 Years
Was £37.99 Inc. VAT
Only £32.99 inc VAT.
ORDER NOW
Team Xtreem 16GB (4x4GB) DDR3 PC3-20800C10 2600MHz Dual/Quad Channel Kit @ £279.98 inc VAT
Team Xtreem LV DDR3 2600 Quad-Channel CL10 uses selected chips and passes 100% stringent testing. 2600 MHz speed rate with 20,800MB/sec transmission bandwidth and covered in the super slim aluminum heat sink, to lift the transmission speed and quality steadiness to another level.
It is the only one to meet the extremely high standards of the 1T Command rate in the market, and its efficiency is 10% better than any other Quad-Channel memory!
Team Xtreem LV DDR3 2600 Quad-Channel is designated to exceed enthusiast’s high expectations by bringing them the ultimate OC experience.
- Fully compatible with Intel P67, Z68, X58, x79-based DDR3 motherboards
- XMP Ready
- High frequency and Low latency
- RoHS Compliant
- Larger capacity:4 GB Kit (2GBx2), 8 GB Kit (4GBx2), 16 GB Kit (4GBx4)
- Equipped super thermal conduction heat spreader
- 100% Tested and Verified
- Lifetime Warranty
- Data transfer bandwidth 20,800 MB/Sec (PC3 20,800)
- CL-value: 10-12-12-31 1T
- Working voltage: 1.55-1.65V
- PCB: 8 layer PCB
Was £299.99 Inc. VAT
Only £279.98 inc VAT.
ORDER NOW
is it worth getting 8gb or 16gb samsung green for a z77 setup running games ge eral windows apps and a little bit of encoding?
Am I confused about what the word "weekend" means? you've just this minute put £3 on the Samsung RAM .... right as I was about to order two sets :mad:
Ordered the Samsung at £41.99 but just seen this thread saying £39.95 and it's still weekend?! Which is the correct weekend price Ace Modder?
Was just about to order a Samsung Green 8GB kit with a 3570k but er.. the price isn't what you posted here :/ It's still the weekend isn't it Sunday evening
EDIT ye I clearly didn't read the thread through before posting :D my bad
What are the chances of the samsung green dropping to this price again? I really really want 2 kits for my x79 rig. Sub £80 for 16gb would be very nice for my pocket.:)
Status
