really this pump is not up to the job stuff is a bit annoying sometimes
does the pump have to deal with a lot of pressure in a pc ...... nope
depending on position most internal loops are what 3 feet high at most lowest to highest point..
so say 3 feet = 1.6 psi of head. hmmmmmnn add in flow restrictions and resistance... even if you double it (which it no way would) that 3 psi give or take or rounding it 6 feet of head pressure...that would be if the pump was at its lowest point in the loop and in an open system..
as long as the flow rate of the pump moves enough water through the system in l/min
and you have adequate volume of water ( longer time to ambient). and turbulance..
is all that matters. isnt it....?
im sure people get over sold on pumps when a ek 2.2 400l/hr job would do the job in a low resistance high volume system (volume is the key)
does head pressure of the pump matter when its not having to pump up hill and you have a low resistance enclosed set up .....? imo nope
give the pump good prime. and away you go
im sure a lot of people go ott on pumps to try and overcome flow restriction and perceived pressure requirements
instead of making the flow rate and turbulance in their systems higher
isnt it higher flow = better cooling
not higher pressure = better cooling
but higher flow is only dependent on tubing size (per given pump flowrate)
1 open a hose pipe up and u get high flow but low pressure..
awesome cooling for a pc
2 close the hose pipe as in make it a nozzle put your finger over the end making it high pressure = low flow and bad for pc cooling.
but so many people talk of high flow systems with restrictive flow and small bore tubing..
so can we have a 25mm id cooling block and a 25mm id pipe system please
with larger fittings than 1/4 bsp (19mm) as the little pumps we have will be more than be capable if we open up the flow rates but also introduce turbulance. (in an enclosed system which is what we have)
making sure ofc that cooling blocks have as much surface area as possible with flow rates that can cater for large bore tubing..
anyone going down that root or am i asking to much...?
im sure its easy to do if we had higher flow blocks .... any development in these areas ??
seems people say buy a bigger output pump.. but it would be better to buy bigger bore system.. the pumps we have can handle it but the pipes/blocks/ fittings cant it seems handle the extra low pressure flow.
if we keep the same size pipes fittings blocks all we do buy increasing pump output is increase the pressure in the sytem. we would be better increasing flow rates at a lower pressure.
so its up the bore size not up the pump output. for now the max id (generally) is 16mm /19mm od lets go big bore tubing and fittings..
ala cpu deluge not high pressure spray ..
