Since starting playing again I have been racing the MX5 at Limerock, which previously I had got ok at, but I still make silly mistakes. I find myself running wide too often, I am just very inconsistent. Car setup if fixed.
I'm also practicing in the Skippy at Okayama, with standard settings but also tried some settings last night which made things a bit better although I can't quite remember. With the Skippy it just feels like it's always sliding all over, I get a lot of oversteer and end up spinning out far too often. I am JUST about able to get round the track now but I'm not confident with it.
G25 settings are all standard. In game force is default, not sure what that is. Screen res is only 1680x1050 on a 20" monitor, FOV is default.
General problem is inconsistency and not feeling 100% in control of the car when cornering. I'm obviously trying to avoid braking whilst turning, and accelerating too hard out of corners.
I cant help with the skippy but I can help with the mx5 at LRP.
First of all dring the FOV down to about 70-73 its a nice place to start and then aim to bring it down to the FOV iracing gives you or as close as you can get to it without it making you feel like your sat on the bumper. (Iv e setteled on 69 now using a 24 inch screen)
It doesn't half help you Hit the apex and judge turn in, one thing you loose a bit of sense of speed.
in the logitech profiler make sure the ff is round 106%-109% Most use 106% i use 109% but start with what ever one else uses, then set everything else to 0% and untick centering spring, you want all your forces sent from the game not the logitech software. Then ingame set the MX5 FF to 14.8-15 this is where i find it starts to feel realistic.
Then try and be as smooth as possible I can do a few laps if your really stuck with you and see if your pushing to much or not enough into some of the bends at LRP, Make sure TIRES are turned up also so you can hear the audio aids to the tire is about to give.
Try those first few settings first see if they help
), so I generally just got used to the text chat and assigned buttons for adjust the voice chat volume so I can mute it easily enough whilst racing if needs be
