Two sweet deals on today only at incredible pricing, don't miss out!! The MSI HD 7850 Power Edition Twin Frozr IV is one of the fastest 7850's on the market and you can now pick one up for less than £200! & The Samsung S23A550H is an Ultra Thin LED 23" HD Monitor with VGA and HDMI input connections which is perfect for any user. Today you will save a HUGE £60 on this monitor, so hurry before they all sell out!
MSI HD 7850 Power Edition Twin Frozr IV OC 2048MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
Key Features
Power Edition Architecture
- Triple Overvoltage: Adjustable GPU, Memory and VDDCI via Afterburner to unleash the potential of the graphics card
- Enhanced PWM Design: more phases provide higher overclocking capability and better stability at peak load
Twin Frozr IV cooler with Dust Removal technology
- Provides 22°C Cooler and 11dB quieter operation than reference product
- cooler removes dust build up every time it is switched on to keep cooling performance optimal
Military Class III Components
- Components meet US Military Standard MIL-STD-810G to ensure the best stability and quality
- Hi-C Caps, SFC and Solid caps are the most reliable and efficient components available
MSI Afterburner Overclocking Utility
- MSI's exclusive overclocking software
- Built-in Kombustor stability test software
- Built-in real-time video capture software
<Font size="4">Specifications</font>
Graphics Engine ATI Radeon HD 7850
Interface PCI Express x16 3.0
Memory Type GDDR5
Memory Size(MB) 2048
Memory Interface 256 bits
Core Clock Speed(MHz) 950
Memory Clock Speed(MHz) 4800
DVI Output 1
HDMI-Output 1
Mini DisplayPort 2
HDCP Support Y
HDMI Support Y
Dual-link DVI Y
Display Output (Max Resolution) 2560x1600
RAMDACs 400
DirectX Version Support 11
OpenGL Version Support 4.2
CrossFire Support Y
Warranty3 Years
Only £199.99 inc VAT.
ORDER NOW
Samsung S23A550H 23" Widescreen Ultra Thin LED Monitor - Glossy Black @ £119.99 inc VAT
Do you want the best-looking display on the market, both in terms of industrial design and image quality? How about a monitor that does more than just display content, one that simplifies your life and is eco-friendly? Samsung’s SA550 LED monitors deliver ultimate image quality, unparalleled elegance, and a suite of features that make them eco-friendly and easy to use.
You can make an artistic statement with a SA550 LED monitor because its design naturally blends subtle color gradations into the monitor frames. The bezel combines a crystal look with Samsung’s Touch of Color, and it is complemented by a transparent base. Also, the cables from the SA550 are hidden in the neck of the monitor so you always have a simple clean look.
The SA550 LED monitor has features to make it so easy to use, while helping you save energy. This monitor uses close to zero watts when it’s in power saving mode. The Eco Motion Sensor alerts the monitor when you sit down and when you walk away, automatically powering it on and off. And, the Eco Light Sensor automatically adjusts the monitor’s brightness to match the ambient lighting in a room. If the room is sunny, the picture shines brighter and in darker surroundings, the intensity is reduced. The result—reduced eye strain and smarter power consumption.
Features:-
- Screen Size: 23" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 10000000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x HDMI, 1x Analogue
- Warranty: 3 Years On-Site
Only £119.99 inc VAT.
ORDER NOW
Key Features
Memory Type GDDR5
DVI Output 1
HDMI-Output 1
Mini DisplayPort 2
HDCP Support Y
HDMI Support Y
Dual-link DVI Y
RAMDACs 400
CrossFire Support Y
Warranty3 Years
ORDER NOW
Features:-
ORDER NOW
just hope its quiet
