How is it for noise? From what I've read the fans use 5pin connectors and the machine shuts down if any of them are doing less than 1000rpm. That's fine if it's already reasonably quiet but a real problem if it needs replacement fans
Thanks for the Kingston part number, it's a little cheaper (£27 for 4gb) than the Crucial. Does it come with 2x1gb or a singe stick?
I'm assuming it's a bit like the Microserver in that the 4disk bay uses a SAS connector and there is a SATA socket on the mb for a DVD? How many SATA sockets does it have?
I'm assuming the PSU is a nonstandard size?
As i do very little with it right now apart from running 1 Virtual machine via Hyper V and having only 1 250gb HDD, it runs very quiet indeed. I have my main pc in the kitchen and the server sitting beside my unit and its not destracting by any means (I wouldnt have it there if it was mind you).
In regards to it being like a Microserver. I dont think so. Originally i was going to go for the N40L but after much debate and taking things like the maximum amount of RAM was only 8GB, the ML110 seemed the better option for me with better scalability. I havent looked into yet but at least the ML100's Intel processor can be changed down the line should i be running a more sophisticated setup. The ML100 hs a Dual core 2.9ghz processor from Intel where as the n40l was only about 1.5ghz IIRC.
My machine came as standard wioth 250gb HDD and DVD/RW drive, keyboard & mouse. Some companies advertise the machine without the DVD and accessories so thats one to watch.
Another thing that made me go for the G7 was the fact that it offered better RAID facilities. Im not using it right now but im sure once i begin my Server 08 admin studies i'll be looking to get my head around how it works from 0-10.
Other specs are as follows:
4 front USB 2.0 sockets, 4 x Rear
2x Gigabit LAN ports
Serial port
Twin ps2 ports
4 x Exansion bays at rear
5.25" drive at the front below DVD drive (Space for more HDD's possible
4 x HDD bays (3.5") SATA non hot swappable (Max 2TB)
Not too sure on how many sata ports mate. Sorry.
Real good bit of kit for the money and for what im doing. I brought mine for the soul purpose of helping me with my Microsoft certifications but down the line i'll kill two birds and rack out the HDD's and ultilise them for main pc storage.
