Just stuck the superhub on modem mode and added an Asus RT-N66U... and I'm rather impressed... it's given me a massive improvement in latencies - greatly noticeable when browsing the web & a good few ms off in BF3![]()
Only issue is needing to switch between the 2.4Ghz and 5Ghz options occasionally but that's not the biggest problem.
Why do you need to switch? You can use both at the same time - I do.
Anything that allows custom firmwares you can't go wrong.. I've got an Asus RT-N16 and couldn't be happier.
I think he means on the client... the router broadcasts two networks simultaneously, you have to manually switch between them if you want/need to![]()
Apple Airport Extreme N
So choose the 5G band one if you can and leave it, if you can't then choose the normal. No need for switching between them at all?
