Had some fun yesterday!
Congratulations mate, looks gorgeous :cool: What monitor are you using, also whats sort of fps and vram usage are you getting playing bf3 ?
I use a single Samsung S27A950D 120Hz. So, yes, they're overkill! :p I get anywhere between 100 and 200 fps at times and VRAM usually tops out at about 1.9Gb but generally 1.7Gb, that's with everything on ultra.
^^As above, they look amazing!!
Love the inclusion of yourself in the second-to-last shot
Haha! I didn't notice that!
See now why did you have to go and do this?
Now I want to do my 670s (the Gigabyte Windforce 3X coolers get a bit noisy from 1500rpm or so) which is leading me back to the TJ11 which I'd just about escaped from the pull of...
If I crack it's all your fault Rossdh, you and your spiffy looking 680s...
I say do it... It's only money after all.
That's what I tell myself, then when the parents ask "how much have you spent this time" I reply with answer which is usually a quarter of what I spent!
