- 18 May 2010
- London
In games that efficiently use multiple threads, how does the the 3570k stack up against the 3770k?
Probably not much difference, the only situations where you're likely to see a benefit from hyperthreading is when the four physical cores are absolutely maxed out.
Ok.
But looking forward, do you not think that a 3770k is more future proof than the 3570k for games?
If you can spare the extra cash then possibly yes. Since sometime in the near future games will hopefully start using more than two threads.
2008 called.... It wants its argument back.....
If I have a quad core machine, then I can have 4 threads running simultaneously. 1 thread per core.
If I have HT I can have 8 threads running, 4 primaries, and potentially another 4 threads running filling in the spare cycles.
It isn't a case of games using more than 2 threads...which I'm also not sure about as a statement. I would be very surprised that complex games spawn only two theads...It isn't a game of pong is it!
I know how processors and threading works didn't you look at my sig? Most games don't use more than two processing threads at any one time at least not fully use them (due to the way it process' it goes across almost all the threads but not one of them will be being used more than 20% usually unless your playing a CPU intensive game which very few games are)
Not here argue, but....
Point 1: Why does you sig illustrate your ability to understand how a complex game engine is built? Are you a software engineer? have you done low level multi-threaded applications? If so, you don't seem to argue very well..."look at my sig"?!?! WTF?
Point 2: A thread can only run on 1 core at a time, although it can switch over to another core...but affinity is good due to having to also swop over memory being used within the caches...as I game on BF3 MP I see clearly all 4 cores running at 70-80%....therefore I would conclude at least 4 threads are running.
Seriously? 2 threads? Come on, it doesn't even sounds remotely right.
Save your money and put it towards a future upgrade.
Well, then welcome to the club...I write multi-threaded apps all day long that do data analysis. But I'll admit I have never written game code. But within Frostbite 2 I'm pretty sure there are plenty of threads (maybe hundreds) running, but I will say that they probably are not all doing something all of the time.
Good luck in your studies...hopefully your in the UK? We need more engineers in the games industry.
Yes. That's what I'd be buying if it were my own money.
£75 extra (or 39%) is appalling value for money for an extra 0.1GHz base clock and a bit of extra cache.
