- 16 May 2005
- Manchester
First bug found. I forgot to enable the online user tracking plugin. There are more than zero players on the server
Whenever I try to install Technic it says cant find java directory.
I'm on a 64bit OS
Cheers
nuttyprot has a good pack
also has all the mods done too but you have to do some work to get it all to work together first
http://minecrafthdtexture.com/author/nuttyprot/
Would it be possible to have all the download links to everything on the front page of this thread to make it easier?
for those of you new to ic2 http://wiki.industrial-craft.net/index.php?title=Tutorial:First_Steps
These mods are optional, right? Robo - any reason?
Robo, the stuff is not that invasive, you could quite easily play without using the automated bits. You never know, you might enjoy it![]()
tl:dr - stay![]()
