Got my 3770K running at 4.4GHz at stock voltage with a simple multiplier change, stable under Prime 95 small FFT with max temp around 60 degrees.
Then tried the Auto overclock button on the MoBo (Asus P8Z77-v) and it's come up with 4.851GHz @ 1.39v
Did a 10x run through of IBT with the max temp of 82 degrees on core #2. Average load temps while transcoding, gaming, etc. max out at mid 60s.
So lucky. You might be able to fibe tune that 4.8 to lower voltage. Auto usually overkills on voltage tbh.
Yeah that's what I got from Tom's Man vs Machine overclocking article, ASUS boards like to up the voltage by more than is nessessary.
10 ibt very high on 1.2V at 4.8GHz...
Temps are awful though. Hottest core hit 93C, though coolest was only 80C.
Must remount phanteks.
Hope I can hit 5GHz.
I run at about 90C-100C at 4.5Ghz >.> you guys be lucky.
ouch....
