There have been recent improvement to optimise the menus for the Pi, so if the comments about 80% processor usage are over a week old then you can ignore them.
I'm 95% certain that in-menu processor usage is down in the 7-8% range. I'll check again tonight and post a copy of my guisettings.xml for comparison.
I had some issues with both OpenELEC and Raspbmc when I had some meta data stored with my videos (fan art, series info, actor info, etc.). XBMC would continue at 100% usage after a scan completed, or even on loading movie thumbnails. After I removed the meta data then everything started running properly again.
I've started again from scratch (same build) and things are looking different - my 'recently added movies' art wasn't appearing before and some other art was missing which is now there. The difference is that this time I didn't go gung ho into playing movies before it had all settled down so it's looking promising. Will wait for CPU to settle (its about 80% at the moment) before doing anything as I have quite a few films.
