Caporegime
- 18 Sep 2009
- Dormanstown.
Anyway the OP stated the following:
"as money isn't exactly flooding in"
Its best,the OP saves up a decent amount and do a decent upgrade/rebuild then doing something half-arsed.
So,IMHO they should wait a few months anyway.
Nothing half assed about an i5 Ivy at all. Doesn't sound like he overclocks, he'd be set for a long time with it.
Unless you're referring to an i3 2100, in which case I'll agree.
Any luck I think I know a friend of the family who's changed countless hardware, but should I do it for the experience?
I'm pretty sure the card I want is the overclocked 7850, cheap and almost reaches 7970 range from what I've read, but if I go Intel am I best off using a Nvidia with it? If so whats a comparable Nvidia to the 7850?
but I get that Intel are better for the long run, but somewhat more expensive and more work, whereas AMD are better for the short term with little to no effort. Something to consider also would be the need to upgrade both G and CPU's at the same time, to avoid them holding one another back if done seperately?
