Project Nostromo
Man of Honour
30 Oct 2002
Surrey
Project Nostromo
Replacement rig for my SR-2 which has done a sterling job as my primary VMware work machine, running multiple VM's while folding away for the Worlds Greatest Team<tm>. :D
But I wanted to optimise the performance whilst maintaining or lowering my power usage in the office. Plus I wanted to test overclocking the G34 Opterons.
This is my hobby, my sickness, so if you feel the need to express your disgust at all things DC then please don't expect me to respond :)
This isn't my first WC Opteron rig, but its going to be a bit more special hopefully than the last and I am going to try and resolve some issues that have arisen from that build in this one.
So this really will be a work in progress, I haven't started yet, I've just been waiting for all the parts to arrive and a suitable evening to kick off the build.
But to begin with here is the plan and some pics of parts that have arrived.
Motherboard: SuperMicro H8QGi+-F
CPU's: 4 x Opteron 6166 HE 1.80 GHz - Socket G34 LGA-1944 - Dodeca-core (12 Core) - 12 MB Cache
Memory: 32GB DDR3 (16 x 2GB) 1333Mhz Low Voltage Ram
Case: Xigmatek Elysium Full Tower Case - Black
Cooling:
Radiators: Swiftech - 1 x 360 + 1 x 240
Pump: D5 + XSPC res or DDC 18w + XSPC Res (Have both to try)
Blocks: Aquacomputer Kryos G34
Fans: GT1850's
Fittings: Various compression and barbs, I'll decide as I go.
This rig will be optimized for cooling, noise is secondary, but reasonably important. We will see this time how it goes :)
Pics:
Parts arriving:
Block fitting plans...
45° fittings fit ok:
0° Fittings no good :(
Combo 0+45° fittings might work..
Hmm.. 45° compressions have smaller internal bore through the turn could be restrictive.
Maybe better to go for barbs.. no restriction and fit fine..
What performance boost do you get from Haribo, apart from a sticky mess in the watercooling pipes?
Om nom nom nom nom nom.
Strange RAM choice though. 2gb sticks in this day and age?
You need to populate 4 slots in each bank to get the optimum memory performance this was just the cheapest way to do that. Plus i couldn't find low volt 1gb sticks anywhere :)
The performance of keeping the kids out of my hair :p
Update: All the parts are now here, managed to snap a few shots before heading off this morning.
Blocks, cpu's, Pump/res and PSU, and something else :) ... New toy :cool:
CPU closeups:
Elyslium box is a monster!.......... But whats reallyscary is the size of the mobo box :eek:
Not so big a difference in size between the P80 and the Elysium. Well not from the outside at least!
THE MOBO UNPACKING CEREMONY!!!! :cool:
Oooh..... Ahhh....
Oh.. :(
Ooooh.... er.. pink! :p
Now THATS more like it! :D
So far I NEVER NEVER understood why the so called "Enthusiast" motherboards have the PCIe slots perpendicular to the RAM slots while the "Server" motherboards have a MUCH MUCH better Aerodynamic layout, with the RAM slots parallel to the PCIe slots, and because this issue I am continuously considering to buy a TYAN or Supermicro "Server" motherboard
Edit: The "Server" motherboards even have the 24 pin power connector "parallel" to the PCIe and RAM slots
Need updates!
Did the elysium you got have the side window? Im thinking of taken the fan off mine and replacing it with a tinted perspex screen.
