- 22 Aug 2003
Hi
My PC has been freezing up quite a lot in the last copuple of weeks and basically I am going to upgrade mine and hopefully get my daughters PC up and running with a mixture of bits from her old pc and mine
however my pc keeps locking up and doing this in the picture
by looking at the picture could this be a Graphic card problem I have tried the monitor on a different PC and it works
I dont want to put a duff part in my daughters PC if I can resolve the issue now
the PC just stops dead in its tracks and I get the blue dotted lines as seen in the piccy
pressing the reset button gets it rebooting but the blue lines are still there all the way through windows loading then they dissapear when its loaded
20 minutes later the same thing over and over
I have reseated all the memory checked the card is in properly and checked the cables are all as should be
hard to put my finger on whats going on.. and I also downloaded the latest Nvidia drivers
thanks
thanks
