	The rankings in that list are for stock speeds. I may push more when I get my rampage board. Need 8 Pack to come bench his beast, think he's upto 5.2ghz on his sb-e and could be pushing 20k.
	How's that? Is using 2 cheating![]()
Not really that much of an increase it seems.. But then again it's not clocked as high as the others.
	Passmark CPU: 6163
i5 750 @ 175 x 21 running 1.2v (only).
Purchased the chip in April 2009, and fair margin under it's overclock limit so pleased with that score.
	Out of interest what temps do you get in coretemp / real temp at 1.2volts and does it show 1.2 volts under load or idle?
	I'm seeing around 61c on core temps during Cinebench. My CPU always shows 1.2 volt, I have CPU C2/C3/C4 states turned off (C1 is still on) so voltage is not dropping at idle.
I also only have a Arctic Freezer 7, and have set so it's fan kicks in late, at these temps it's only running around 1800 rpm, 2200 rpm is it's max. I am using recently applied IC diamond 24 that helped temps somewhat.
Also: I'm running a Seasonic X650, it has very stable voltage output and allowed me to run lower voltage over previous OCZ 600.
67c on core temps during Cinebench. Get running Intel Burn test maximum, then should warm up your CPU properly and see if its truly stable at 1.2volts
My C1E, C3, C6 are all disabled as is EIST and thermal monitor.
I'm running a corsair TX850
Going to try dropping volts down a bit to reduce temps
edit - I set volts to 1.27500 in bios which is 1.216 load, 1.2482 idle. Cinebench passes with max temps of 64c. However IBT max blue screens as I guessed.
Volts are now at 1.28750 in bios which is 1.232 load, 1.264 idle. Cinebench 67c. IBM max passes at 83c
