Eurocarparts 30% off - August update
always loads of cods but thanks anyway, just ordered a set of pagid rear discs and pads for £140 all in, sweet :)
just bought front discs and pads for £80 (the 30% discount made it just about cheaper then the other sites, and a set of brake carriers from a breaker for £78, so £158 to upgrade my 288mm discs on the leon fr tdi to 312mm...happy days :)
Just a heads up for anyone looking for any braking components
I was recently looking around on parts sites such as the two listed above but they didn't come close and didn't even stock original callipers.
I went to www.brakesint.co.uk
They stocked the oem callipers all remanufactured and looked brand new , they had even reground the mounting points and came with a carrier too. such a good service and even knock £10 off when you send your old one back, plus much cheaper than buying the pagid parts from the listed sites above.
That carparts4less is CHEAP!
Just ordered a SACHS dual mass & clutch kit for my Passat, came in at £295 inc postage!
My mate has a trade account with Eurocarparts and could only get it for £308 plus delivery!
Is that TDi..?
