- 28 Apr 2011
- North West
Hmm I thought it was ok to keep it at anything under 100c.
Volts are 1.260 4.5Ghz avg 65c atm
not really - you need to keep it below 60C reallysorry
its fine? not sure if your being sarcastic lol.
as i said there's a lot of info i this thread already.
Definately should be running under 60 24/7... with 70 your load temps would be horrendous.
those are the load temps from 100% folding64-70c. idle is 21-30c.
Is 35C idle fine?
4.8 @ 1.2V ????!! thats an amzing chip if stable
that was under load in IBT. Would vary from 1.192V to 1.208V, usually 1.2V
Under load in prime it will be anywhere from 1.2V to 1.232V, usually around 1.216V.
Either way, even if I still only need to nudge it up a bit, it's still a pretty decent chip i'd say![]()
Watercool and smash that baby past 5GHz![]()
