New Macbook Pro
22 Jun 2005
Nottinghamshire
I bought a new i7 macbook today, its the previous model.
I currently have a late 2008 MBP with 1 ssd and 1TB hdd.
Is it possible for me just to take the SSD hard drive and put it in my new macbook?
Sure no problems with that :) If you need any help, iFixIt.com has some decent guides :)
Obviously, if the OS is installed on the other hard drive, you'll need to do a fresh install on your SSD. If the OS is installed on the SSD, then it's just a straight swap :)
He's asking if he needs to do a re-install or not, not if it will function...
A windows machine would not be happy if you tried to run it with an install set up with drivers for a different machine.
A Windows XP install can't handle being put into a completely different computer. Windows Vista and 7 can though.
