Draw Something bought! Was getting tired of the ads after goes. Now to wait and see if they do the same deal for Words With Friends!
WordFeud is still free version as the ads in that are so quick to skip.
So do I... There are ads, it's not in game it's between turns., the ad screen shows a video which can be skipped after a second or two but if you skip too early, Draw Free crashes. This is an ad that AdAwaye/AdFree can't remove due to the way it's implemented much like how WWF has their ads between turns.
I bought GTA 5 days ago for full price, gutted!! I know it's only 3 quid but I still wanted to moan!!
Also anyone got any ideas why NBA Jam and Mass Effect are listed as not compatible for the GS3? I wouldn't have minded these two, typical!
I'll put something positive in here as well, been enjoying Super Stickman Golf recently, so I'd reccommend that.
Cheers.
Thanks Siliconslave but I think you only get 15 mins for a refund from the Google Play Store these days. Like I said it's no real issue, but if you can't have a moan on the internet then where can you!!
Any idea as to why my sgs3 is talking to me...I've installed lightflow and now everytime I open up a folder, it says opening folder then closing it says closing folder.
I've had a look in the accessibility settings and I've turned off the voice commands but still does it...If I disable lightflow then it stops but that means lightflow doesn't work.
Any ideas or is this a bug in have to live with???
You have talkback on don't you? You only need to enable light flow in accessability, not the other.
