- 23 Apr 2012
- Edinburgh
What voltage are you using for 2200? Seems I have a huge jump in voltage needed to go above [email protected]
let me know if you notice a big difference vs 1T thought and I'll try and get my 1T stable ...
are you using latest mb bios? ive seen these sticks run at 2133mhz on gigabyte z77 boards 8gb with 1.55v dram voltage
tried with 1.10v cpu vtt?
While it turns out my new 3770K is a decent clocker, the IMC ain't great by the looks of things.
Was able to run this memory at 2133 11-11-11-28-1t on X79 board with just 1.425V, but on this I tried similar settings, al the way up to:
1.5V DRAM
11-11-11-28-2t
VCCIO at 1.2V
but would will fail ibt very high on second pass without fail.
Was hoping to hit 2133, but not looking possible. Would I likely need to up the dram voltage even more?
Just seems odd, knowing that it is quite capable of doing 1.425V on another platform.
Or could it be my z68?
I have a similar experience, my RAM does not seem to clock as well for some reason without significant volts. Could well be IMC if your CPU is the only change, could also be 2nd/3rd timings need adjusting.
1.425 for 16GB at that speed does look like low voltage compared to settings that other people have posted
Z68 is not great for RAM clocking mate, especially with full dimm population. Also the 3 series ASUS bioses supporting Ivy on Z68 are very immature. They are being worked on as we speak.
Having said this 2133 should be fine with two DIMMS.
Oh well, will try and get around 2000 with 10-10-10-28 (roughly) and live with that, and see if future bios updates improve things.
Not really going to notice much of any difference
Dude, just an FYI.
I'm sitting at 2000MHz @ 8,9,9,21 1T @ 1.62v
I would advise you try and tighten those timings if you can't push the frequency.
I think i'm going to go back to BCLK 100 and move on up to 2133MHz... I can't seem to leave it alone!
Yeah, but you're on x79 - I am back on a plain old z68
I can live with the 2000 for now. Got it at that with 1.475V.
If future BIOS improves things, then awesome, but at the moment I am not not sure I will try new BIOSes, as my chip is running to bloody well on current.
it's a load of fun.You're mainly limited on frequency, you should still be able to tighten the timings.
You need to get a Z77 board mate, or return to X79![]()
it's a load of fun.
Cheers that worked. least I can bench with memtest now....Cant help with the overclocking but if you have a spare USB flash drive you can run memtest86+ off that. Use the installer here, the one listed as new: http://www.memtest.org/#downiso
