Watercooled pc.. Ocd wiring.. by
http://www.samcatchesides.com/, on Flickr
Not finished on the wiring yet (not neat enough), and the lighting is the next project... Full custom diy RGB led system...
The res mounting is temporary until its been redrained and refilled.. Tie wrap isnt really a great permanent solution.
And the Dynamat thats visible will be trimmed and removed so its not visible on the back of the other case half (even though you cant see it when the case is together) ...
i7 2600k
ati 6990
ASrock extreme 4 gen 3 mobo
16gb corsair dominator
200mm rad in front with push/pull 200mm fans
120mm rad in back with push/pull 120mm fans
200mm fan in roof
Lots of carbon bits, and lots of time spent hiding wires...
Full photoshoot soon, when I can be bothered to pop it into the studio.
Sam
