- 20 Jul 2004
- Dublin, Ireland
Yep be sure to use the Official XBMC remote for android - the other unofficial one does not work.
Nate
Nate
Here are a few settings I've found over a bit of messing with OpenELEC (more than likely apply to Raspbmc as well) that should improve some stuff:
1) Do not use Samba, if possible use NFS or FTP share instead.
2) Wait until media indexing has completed before trying to play any files
3) In Settings->Video->Playback enable "Sync playback to display" and set "A/V sync method" to "Audio clock". This should help with buffering issues when having to down-sample audio.
4) In Settings->System->Video Output set the "Refresh Rate" option to something appropriate. (e.g. 24.00 if you are displaying on a TV instead of a monitor.)
5) In Settings->System->Audio Output enable pass-through for the audio types your TV or receiver can handle. Down-sampling audio will push the CPU on the Pi to the limit.
6) Turn off any of the services you don't use. (e.g. AirPlay, Zeroconf, UPNP, etc.)
On further look, RASPBMC is broken with NFS shares![]()
Bit miffed.
Got Raspbmc installed... and it seems to be very slow? Playing 720p TV series MKV and it isn't smooth at all... pauses etc.
CPU usage looks to be 50-70% idle :/
Is OpenELEC more stable?
On further look, RASPBMC is broken with NFS shares.
Works perfectly on RC2, not upgraded to RC3 yet (really need to) but NFS works for me and seems the best option (just a shame the only linux setup I have right now is a VM but that will be changing 'soon'![]()
Who is running their Pi off of a USB port from a TV? I read that it should use a 700ma power supply, but most USB ports will supply 500ma. I don't know what my TV dishes out or how to measure it. I cannot find it in specs anywhere.
Need to find a good case now - anyone got any pictures of their cases?
If tried running my Pi from the USB port on my Toshiba telly that is labelled for the optional WiFi dongle. It all worked, but about 30 seconds after putting the telly into standby mode the power stops to the USB port. This would be perfect if you were just running XBMC, but for anything server like it's not so good.
I want to run XBMC or RaspBMC
Same thing, just RaspBMC is ported with Debian to run as standalone piece of software.
