can any 1 explain this lol.
4.7ghz 47x100 1.224vcore been running aida for 18mins
4.7ghz 47x100 1.28vcore fails aida/prime/ibt instantly bsod 0x124 ??????
when i first got my motherboard i updated my bios, which corrupted first time i've ever encountered problems updating bios in 10 years also first time using msi board !!
wondering if that could be playing apart in my vcore war. i've tried everything.. apart from changing board or cpu.
good luck with this, sounds tricky
42x100 1.28 fails
40x100 1.28 fails
35x100 1.28 fails
the higher i set my vcore the more unstable my system becomes.
tried bios update, all energy saving features on/off, turbo on/off , upping SA/ i/o /mem voltages, different ram seepds, 1333mhz,1600mhz,1866mhz, XMP on/off, 1stick of ram in each slot,different ram, different stress test software.
Installed coretemp, and according to that, my VID at 4.8 is 1.1559V
Edit: yes, I know this isn't a finished run. I wanted to demonstrate what it looks like under load - for a completed ibt run, click the link 3 posts up.
Indeed as other guy said, low gigaflops........ I get 108.xxx at 4.7Ghz so somethings wrong with your setup
What is stock for your memory?
Mine is Samsung Green, so 1600 11-11-11-28-2t
You got same memory?
Last time I looked in IBT (which is not a benchmark) I was getting around 112/113 with 4.9GHz.
Think the memory was at 2000 at that time.
Earlier in the thread you claimed 110 in IBT, now you say 112/113 so which is it?
I've got el cheapo corsair 1600 RAM
I am not likely running the same clocks as then, be it memory or cpu, etc.
I have not been using IBT much lately, and have not been paying attention to how many gflops it was giving, but rather whether it passed.
Not sure what you are getting at here? Is it that you think I am full of £$%&, or is it that you want to say yours is better than mine?
To make you happy, I will do a run of IBT very high tonight, and let you know what gflops I get.
In the mean time, how about you download and run cinebench, and let me know what score you get?
Lulz, no one cares who has the fastest cpu. I run mine at 0.7x volts at 3.9Ghz. I have one silent fan and it doesn't get hot! You are the one who constantly posts in this thread to no ones interest........
I don't need to improve my e-peen if that is what you are getting at mate, though it certainly appears that you are desperate to do so!
