They're going up in price tomorrow. Are you going to wait until it gets some full reviews or bite the bullet? I'm yet undecided!!
Guessing that DP means Display Port but I have no idea what the other stuff means. Hopefully PCM2 or Baddass could enlighten us.What does this mean exactly?
Panel are often labelled SL/A1, SL/A2, SL/B1, SL/B2 and SL/Q1, what does it mean. What does DP indicate?
I seriously doubt that gaming would be enjoyable on a Geforce GTX 275 at that resolution. In terms of an Nvidia card, I reckon you would need a GeForce GTX 560 Ti at the very least and even then you would still need to lower the detail in most of the games.If I buy this monitor (gonna be a last minute decision) it will be paired up with a Nvidia Geforce GTX 275.. Is that a good or bad idea? I'm not sure if the graphics card has enough grunt to tackle 2560 x 1440 resolutions...
A Nvidia Geforce GTX 275 might struggle quite bit with this screen. It might be okay however if you keep to a 1080p resolution.
I have a Nvidia Geforce GTX 580 and so i'm hoping this Graphics Card will manage this screen just fine at a 1920 x 1080 resolution and hopefully bit higher.
You won't have any problems with that card running at native resolutions in BF3 I run at max detail with no problems on my crossover same monitor less the pivot and height adjustable stand.
  Looks perfectly vertical.Not height adjustable, but can be tilted.
Also just checked, both DVI ports on my 5870 show the bios, an old 7100GS nvidia card shows the bios on DVI but a GTX580 didn't show the bios on either DVI port
Panels are often labelled SL/A1, SL/A2, SL/B1, SL/B2 and SL/Q1, what does this indicate. DP is display-port I assume?
