Looking nice! triple 27" .......dammmmn how do you rate them vs your dell...i presume u2711?
Out of interest naan are you running the U2711 in its native colour space or sRGB?
I am just running the U2711 on standard setting - is it better in sRGB? i have never calibrated a monitor before -i dont know how! i find sRGB a bit dull
as far as i can see, the stand is screwed on to a metal plate inside. looks like you will need to remove the 4 screws on the back, this will enable you to remove the front bevel and get inside and unscrew the stand.
I might have a look but want to see official word from DGM/ OCUK that it wont void the warranty first.Come on men, grow a pair and get you hands dirty!
Gibbo - will removing the stand void the warranty?
I had a quick look, removing the screws didn't seem to loosen anything, so i put them back in! Needs somebody braver than me to take it apart. Its only that stupid plastic arm that needs coming off!
Got mine now, still waiting on a response from Gibbo before I dare to open the box.
I presume your running it as an exteneded display? In which case how are you having an issue? or is it eyefinity?
If you do it that way you can set the preferred display in eyefinity and also set which monitor you want the task bar to appear on, so to look at mission accomplished, but of course not as user friendly as extended.
