Retro fit Aero blades?
Put your reg into wiperblades.co.uk search, they will have what you need (and their own-brand blades are really rather good!).
Nice site, thanks for the link :)
Would you say to go for their own brand, as the Valeo ones are almost twice as much, or are they Valeo ones worth twice as much?
I've put Bosch Aero blades on front and back of my Legnum, and on the front of my mum's MX-5, and my dad's also put them on his Shogun, and my step-mum's Hyundai Getz! All of which are the "retro-fit" style.
A massive improvement over standard type wipers.
i've had a set of bosch on my evo for a good few months now, cant say i have seen any noticable difference in performance over the standard bosch wipers, do look a lot better though.
I've had a couple of standard wipers on the rear of my Legnum, and they missed the top part of the screen due to the curvature. The Aero one, though, curls nicely at the end and gets the bit that the standard type missed!
I've also found that they don't make as much of a mess of the screen when it's only lightly wet compared to standard ones.
Sounds like I need to spend £10 then ;)
I've got some no brand standard ones which work ok, but they leave streaks with not much rain, and in this heavy rain were having, seem to skim across the water on the screen :p
Are these really that good? Had the current blade a year and could do with replacing soon.
I trust your judgement Phil so I may order a set for mine, only a tenner, got some £1 bargains on there which are ok and work alright but the fact they cost a quid makes me think at some point they're gonna explode and scratch my screen :)
Won't be long before they skip and stutter across the screen. Best cheapo one I've come across is Wilko own brand, last 6-8 months ish do not ideal but £4 a pair, had a couple of sets on my wife's Astra but will be getting wiperblades own brand next time.
