Air Flo Mini Concept
What started out as a notion of a concept energy efficient gaming rig build centered around the ASRock Z77 E-ITX motherboard has evolved into this...
Case choice
With the Bitfenix Prodigy not yet available in the UK and on a chance visit to *Can't mention the retailer in question* I spied the Silverstone TJ08-E...
Decisions decisions should I wait on the Prodigy...???
Nah lol to impatient to put theory and concept into practice
Any regrets?
NONE WHATSOEVER!!! The silverstone TJ08-E is a great bit of kit and it's build quality is flawless
The Motherboard
My deciscion to remain ATX at the time of upgrading to the Z77 chipset was heavilly inflenced by the lack of information and reviews pertaining to the new Z77 ITX boards available; these being the Asus P8Z77-I Deluxe, the ASRock Z77 E-ITX and the Zotac Z77ITX-A-E respectively.
The past 8 weeks however has seen the ITX concept nagging away at me, that and the fact my own requirements for a motherboard are simply as follows -
With my recent hands on experience of the ASRock Z77 Extreme4 and the impression it left apon me I elected to go for the ASRock E-ITX.
Of the three ITX boards currently available the ASRock Z77 E-ITX is the cheapest offering if you shop about, in terms of layout I believe it also offers the best layout of the three and it's certainly aesthetically pleasing to the eye.
Build quality is absolutely superb, certainly no bargain basement el cheapo quality tag can now be applied to ASRock; this comes from an individual who previously would never even entertain the idea of a motherboard not manufactured by Asus or Gigabyte.
Performance
The overclock I applied out of the box was the 4.5GHz, I used the very same voltages that I utilised on it's big Brother the ASRock Z77 Extreme4; now for a board that only has a 6 phases for the CPU main voltage, one for the CPU VSA voltage and one for the CPU VTT voltage (6+1+1 config) the performance beggars belief!!!
Could it go further...
I set about applying a 4.8Ghz overclock
Ok how far can it go...???
Try 5.1GHz!!!
Even more impressive is that during the testing not once did I have any sort of instabillity or BSD occurence.
Lastly the specs
Case - Silverstone TJ08-E
Mobo - ASRock Z77 E-ITX
CPU - Intel i7 2600K clocked @ 4.5GHz @ 1.285V
RAM - 8 GB (2x4GB) Samsung Green DDR3 PC3-12800C11 1600MHz 30nm Dual Channel running @ 2133MHz (10-10-10-24 2N) @ 1.45v
GPU - KFA2 - GeForce GTX 560 Ti LTD OC 1024MB PCIe 2.0
Sound Card (external) - Creative Sound Blaster X-Fi Surround 5.1 Pro
PSU - Silver Power S460SL 460W 80Plus Gold Fanless Silent Modular
SSD – Kingston Hyper X SH100S3/120G 128GB
HDD - Seagate Momentus XT 500GB
Cooling - 1 x 180mm Silverstone Air Penetrator SST-AP181 (front intake)
Antec KÜHLER H2O 620 with 2 x 120mm 1850 RPM Scythe Gentle Typhoon's (CPU cooler/extract)
Thank you for looking, any comments and feedback are more than welcome
Case choice
Any regrets?
The Motherboard
- It have 2 x SATA3 6.0 Gb/s connectors
- A PCI Express 3.0 x16 slot
- It should be Z77 ideally ITX
- It should both be quiet and energy efficient
- And lastly it should be able to overclock like the Devils own
Performance
Try 5.1GHz!!!
Lastly the specs
