£600 Gaming PC
17 Nov 2011
I've £600 to spend on a gaming PC, The parts I already have is,
PC Case
DVD Writer
Keyboard/Mouse
Monitor
My requirements of components are,
1TB HDD 7200RPM
8GB DDR3 RAM
2x 120mm fan (Must have good dBA and CFM level)
1x 92mm fan (Must have good dBA and CFM level)
If I get everything sorted out, I'll make the purchase tomorrow
Can you explain more the difference between 3570K and 2500K
Sapphire HD 6950 Dual Fan, is the card good and does it make a lot of noise?
Is the Cooler Master PSU good or should I go for the OCZ 550W?
I need a aftermarket CPU Cooler so I can overclock the CPU
sigh, what is there left to say.
- 3570K : PCIE3, better integrated graphics, lower power consumption, 5-10% better IPC.
- 2500K : Cheaper, overclocks slightly higher. I'm on a 2500K and it's nowhere near stretched.
The differences are marginal, we're not talking a massive difference in every department. PCIE3 is moot, since you will never get a card that will make use of the full bandwidth.
1. yes.
2. no.
Is the Cooler Master PSU good or should I go for the OCZ 550W?/quote]
It's good enough for a HD6850 / HD7850. HD6950 / HD7950 / GTX670, imo it's a bit too close for comfort, but it will work.
You can get that later since your budget is already stretched. Better save your £25-£30 now, and spend those on a motherboard and whatnot. Hell, I would drop the fans if you don't actually need them, maybe use the money for a 3570K retail.
Could the 3570K overclock better than 2500K?
I'll go for the Sapphire HD 6950 graphics card
Which one is better? Cooler Master or OCZ PSU?
I can spend £30-40 on a good CPU cooler as I really want to overclock the CPU
What's the difference between CPUs that is OEM and Retail?
They are about hte same really. It depends on the chip you get. It's not worth obsessing over.
Get the OCZ.
Thermalright TrueSpirit 120, Matterhorn Pure, Coolermaster 612S, Gelid Tranquillo.
Either one of these, but my pick would be the True Spirit 120, as I have the older brother the MUX-120 which has impressed me (good build quality, quiet, good performance, good brackets and no ram interference).
Retail : Three year warranty, retail stock fan and box.
OEM : One year warranty.
YOUR BASKET
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM £173.99
1 x Sapphire HD 6950 OC "Dual Fan Edition" 2048MB GDDR5 PCI-Express Graphics Card £169.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £82.99
1 x Seagate Barracuda 7200.12 1TB SATA 6Gb/s 32MB Cache - OEM (ST31000524AS) £65.99
1 x OCZ ZS Series 550W '80 Plus Bronze' Power Supply £49.99
1 x Adata XPG Gaming v1.0 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (AX3U1600GC4G9-2G) £38.99
1 x Thermalright True Spirit 120 CPU Cooler (Socket LGA775/1155/1156/AM2/AM3/FM1) £24.98
Total : £618.92 (includes shipping : £10.00).
It's all over budget, which is why I'd recommend you stick with a retail CPU for a while.
With the Thermalright True Spirit CPU cooler, could I get the 3570K to 4.5GHz?
Get the OCZ.
Will do
How about the Thermalright True Spirit 140? £15 more
It's alright if it's abit over the budget
Do I need some thermal paste?
YOUR BASKET
Looks good olivier has helped you well :)
Personally I'd look at the matterhorn or the CM 612S as they have more copper heatpipes which should help keep the CPU cooler. The 612S comes with a tube of paste the matterhorn has a lil sachet of paste supplied.
What case do you have? It's important to make sure these heatsinks will fit as well as the 6950 GPU
Maybe. It's a voltage thing. Limit voltage to 1.325V and see how high the chip can go. Why 4.5GHz matters?
I'd get the matterhorn Pure / CM 612S if you want to spend more.
No.
This is a picture of my case,
http://i3.lulzimg.com/6d1bb8fe6c.jpg
No.
Which one should I choose? Matterhorn Pure or CM 612S? Is it better than Thermalright True Spirit 120? Are they good?
