Cheers. Stupid question: in CWM, does Factory Reset wipe the SD card?
Nope, FOrmat SD Card wipes the SD card under Mounts & Storage.
I got a bit concerned because it says it's wiping ALL USER DATA.Bargain, I'll try that and see if it makes this ROM boot thenI got a bit concerned because it says it's wiping ALL USER DATA.
Ah I see I gotcha I just flashed a zip with the Jelly animations
I'm surprised they don't have the animations on HTC phonesIs the carousel still there when you swipe really quick on the homescreens?
I like that one I want it on my S2!![]()
Update for Apex is out not much is added though.
Still won't be changing from it![]()
Unfortunately at the moment the Samsung Galaxy SIII is not compatible with our ap. It is something we would like to work on but unfortunately certain changes need to be made to the actual handset before it is capable of running the ap.
There's a fault with the SIII!
Is it possible to sync an outlook email (business address) within the Gmail app? So I can simply switch accounts and check work email.
I mean I know it's possible, but how do I do it? If I go to add account, I think it has to be a Gmail a/c?
Tick multiple items then hit the envelope with the letter peeking out the top. This marks them as read. If you hit it when it shows a closed envelope it marks them as unread.
