- 2 Jan 2012
- UK.
You can flash your standard HD 7970 to a GHZ Edition card, this gives you higher stock clocks, turbo mode to 1050Mhz and lower voltages meaning less power use. Thankyou AMD
I have flashed my reference Powercolor HD 7970 and my non reference HIS Blue PCB HD 7970, both are working fine with the new bios. 1050/1500. Using lower voltages aswell
Use this link for more info http://legitreviews.com/news/13622/, flashing is easy, you do it windows and then re boot, might be an idea to back up your old bios first, dual bios switch makes this so easy and safe anyways.
( If you want use this bios, you need use the 12.7beta driver for get PTE and TurboBoost enabled ( as it contain the software algorythm needed )
