(I will be on a clearance type of fit anyway with this config lol)Do those rubber mounts hold that rad securely enough?
I'd be worried about the weight once it's full of coolant. I can see there's no up /down room for movement, but as the barbs at are the bottom you'll be tippinh the case around a lot to bleed that rad. It could fall inwards if the rubber doesn't hold.
Have you tried already how the GTS280 will fit the top space?
I'm planning to put a Alphacool XT45 240 in there as I don't want to give up on my GT15's and there is no space with the 120->140 shrouds for it(I will be on a clearance type of fit anyway with this config lol)
Nice one mate, looking good. So you didn't need to make any cuts to the drive bays for the bleed screw?
To save you the work of braiding your PSU, why not get one of the braided cable kits that corsair has released recently?
Nope, no cuts made. I might consider drilling a hole to access the bleed screw though. Might make filling the loop easier. And yes I have considered that. But I think its quite expensive to re-buy cables I already have. I also didnt think much to the consistency of their heat shrink to be honest. The lengths were all over the place. I think I will just braid the cables I need, which isnt too many, and only the parts on show in the case.
No other mods needed.
Might drain and fill it tonight with the proper fluid then hehe.
The drain port worked really well. Reminded me of draining a sump on a car hehe
im liking the drain port,green looks pretty good but i think the bay res needs pushing in a touch more
looking very beast and nice and tidy, well done. You have done a great job. Is it just me or is the tubing really skinny?
p.s Temps at idle and load please for all components![]()
Had PC on for around 3 hours, just browsing web. Graphics card is reading 30-32degC ish, CPU is averaging about the same, maybe a degree or 2 more. Nothing is overclocked, and fans are running at low voltages (around 5V). Super super silent though
Tubing is 3/8" (1/2" outer). Pretty standard I thought
I'll keep you posted.
