- 11 Sep 2009
- France, Alsace
I got so much **** for buying the sub and not telling her indoors, this will put me right in the doghouse...
These arrived yesterday.
3x D-links quad port network cards
Quad serial to USB adapter cable
Cisco 2950 24-port. (Ordered 48-port but received a 24-port.)
NOM NOM
From looking at his previous posts, using with GNS3. Though I'm struggling to understand the need for 3 of the cards..You've peaked my interest, what are you going to use the lot for?
Correct.I'm going to use that 2950 switch for now along with the etherswitch modules in some GNS3 routers.
When I have the money, I'll be adding four layer3 switches into the mix. The most reliable method
that I've come across to connect them to virtual routers in GNS3 is a dedicated port on the GNS3 host.
There are other options available, but they each have their problems.
Only emulates routers properly, you can plug in a switch though and set it up. http://www.gns3.net/switching/How can you use the cards on GNS3? I though GNS3 was just software emulation of routers/switches? Will you have a PC emulating routers and connecting from the PC to the switch so the emulation kind of enters the real world?
NOM NOM
Indeed you can.Only emulates routers properly, you can plug in a switch though and set it up. http://www.gns3.net/switching/
As oli said, GNS3 does emulate routers, and it does so very well. I've connected them to my realHow can you use the cards on GNS3? I though GNS3 was just software emulation of routers/switches? Will you have a PC emulating routers and
Haha yes Bennie-Mac it is, got it to go with my KCCO t-shirt, rather chuffed these things are hard to get!
