link does not work.
Kenneth.
It works fine for me on both my pc and my phone over 3g so not sure why it isn't for you
link does not work.
Kenneth.
Thanks Evilpaul!
The image turns my 32GB SD card into a 128MB device when you write the image to it. Is there any way to either increase the image size so it uses all the SD card, or create a separate partition on it?
Or am I then into the realms of compiling the image myself?
Just trying to set raspbian up on mine now and i'm pretty new to linux, When trying to run "sudo apt-get update && apt-get upgrade" I get constant errors once it gets to this stage, anyone know how to stop the errors?
Link because the image is huge
Thanks
seems to use a lot of cpu just moving the mouse around and things are pretty slow
Does anyone have a wifi dongle working, if so what have you got? I'm hoping to turn mine into a relativly portable xbmc device.
Is your network up and running? Can you ping something on the internet?
Thanks
I spent days trying to find info on a working easy to setup WiFi dongle...
Gave up and ordered a WiFi Ethernet bridge instead. Id be interested to hear if you get a dongle working though, far less messy.
Which bridge are you using mate? Would like to get my Pi wireless within Raspbmc, and if you have one working, i may as well go the same way!
Now to get an Ubuntu VBox up and running so I can stick some media on the SD card and test it out.
