Do EGR valves need cleaning?
5 Aug 2006
Derbyshire
Hey all.
A conversation with a friend was about cars and how to maintain them.
He mentioned the exhaust gas recirculation valve and how they should be cleaned.
I quick google shows that there are sprays that you can squirt into them to flush all the **** out.
On my car (2007 Focus TDCI 2.0 78000 miles) EGR blockages are one of the more common issues.
So, is it a case of clean it out, or 'if it ain't broke, don't fix it'?
Really depends on the car and how it's driven we run 2 vectra taxis one has never needed and egr valve cleaned in over 100k
Miles the othe gets done every 20k or so
mine at 140,000 - volvo s60 d5
i cleaned it out but didnt notice much difference afterwards
Ill be doing mine soon on the civic, will take some photos of how manky/otherwise it is.
I have no real reason for doing so other than I've seen how some look with about 50k and I'm coming up towards 80. Oh and I believe the sprays shouldn't really be used - or only be used to help loosen the material that you're scraping out anyway . Careful with the inlet manifold ifyou clean it -anything dropped in there means taking it off, a ballache on most cars
I think it depends on the car. On my car they get clogged up and can effect the performance of the car. I plan on checking mine at some point.
Heres a pic from club forums of how they can get clogged up with carbon deposits.
Do EGR get serviced/replaced as part of the manufacturers servicing schedule?
It will not even get a look in unless the fault codes are read on the car. Not sure if they do this on a service.
If it did throw a code they will replace with new at your cost even if it did just need cleaning
Wow thats quite bad, What car is that?
^ MK6 Honda Accord. They are a common sight, worse thing is they clog the holes that go into manifold, which overtime can cause idle and performance issues, all this useless junk to meet emissions target set by the green brigade.
Check this vid from around 3.30, see how the holes are completely clogged: http://www.youtube.com/watch?v=d8N-SE047VY&feature=plcp
Edit: Just reliased the title of the thread is EGR Valve :o
