8150
27 Feb 2008
Chaddesden, Derby
With the deal today is it worth the £123 (after £20 cash back) to upgrade my 1055T Phenom 2 x6 to an 8150 Bulldozer. Then use the money saved to get a 2nd 6970 2nd hand.
(I already have a 990fx Sabertooth board)
or
Spend £250 on 2500k z77 / IB i5 3570k + z77 board.
Discuss :D
I mainly play games like Battlefield 3 / Skyrim / etc
Also like messing with emulation of older systems
Stick with the X6, the FX has worse IPC than the Phenom IIs.
Then wait for Haswell, but if you really can't wait, then the 3570K.
When is Haswell due to drop and is it rumoured to be much better than 2500k / 3570k?
I suppose another option is to get a 2nd 6950/70 anyway and wait for steamroller or Haswell
I have the 8150 @ 4.60 jiggerherz ^^ only reason i have it though is because i got it for free, good cpu and gets way too much bad press imho.
Q2 2013 according to the roadmap, and it will be exactly the same as 2500k/3570k. Possibly a 0.05% increase in gaming performance (just like Ivy).
To throw even more choices in the mix I have just noticed an I7 X79 with mobi for £380 -2nd hand although that might be overkill for my needs
Ivy was mainly a die shrink, Haswell should be pretty interesting.
And Ivy's more like 5% around better than SB.
But you're not sensible when it comes to Intel, so why am I bothering.
I'd get it.
Your CPU would bottleneck a 6970 Crossfire, as would an FX8150.
It doesn't get way too much bad press, it's just not very good for gaming to compared to what's available (And been available since 2008)
Having weighed up the pro's and con's I think I will go for a 2500k with a z77.
The Bulldozer just isn't a big enough step up even though a cheaper upgrade option.
The lower power requirements would allow me to add a second 6950/70 without upgrading my 600w psu. My Ram and cooler are all compatible (for x79 would need a new psu + cooler)
Unfortuately the 2500k seems to be higher in price more recently - although motherboards seem to be cheaper. So might wait for a deal.
Why get a 2500k when you can get a 3570k? If you expect a 4.6ghz+ overclock sorry to disappoint but the newer sb chips struggle to get that high from what I understand.
Sorry, should I be a die hard BS spewing fanboy like you instead? :D
He doesn't BS. The facts are there. Haswell will be an all new architecture with a pretty good improvement to IPC as well as the igpu....
