Happy with that.![]()
did some accidental experimentation last night (bios update - you can't save your oc settings)
seems memory speed does effect Vcore required ... these with my Samsung memory
1600 1.35V, CPU @ 4.5 - needs 1.225V
2200 1.45V, CPU @ 4.5 - needs 1.285V
quite a difference
5 hours of P95 completed (4.3GHz @ 1.216v) with a max temp of 77*c, but there were 7 WHEA errors. A very slight nudge up on the voltage should sort that though?
Ok so here is my two cents
4.7GHz @ 1.33v
10 hrs prime stable
5 passes IBT max stable
this was just 10 mins but 10 hrs saw my temps hit 67c
funnily enough 4.8GHz i limited by volts and not temps? 4.8GHz takes too many volts, 1.43v but temps after 10hrs prime only saw 75c!!!! so im going to stick to 4.7GHz![]()
