SWG Emu
someone dragged a krayte dragon back to the cantina in Mos Eisely they were trying to get it to kill the afk dancers lol. Then the server crashed.:D
Wow swg severs been up all day, just removed in to pc from a hotel using splashtop2, awesome. Swg controls are a bit hard on touchscreen, but good enough for sampling and crafting.
Mined 8k low grade ore + what ever may miners mined, but that won't be much, since 6am. Only need another 147k low grade pre and 77k gems to unlock city hall structure. This may take a while.
Have we decided which planet yet? And if so anyone started thinking about where is bet and done some recon?
It be great if we started city early, we could group up and earn money mega fast, each take two missions each and it would be a walk in the park, could easily do 4k missions and the xp would be amazing. We could just find an area set houses up and then when we have city hall, pick up houses (I think that costs 1500 credits, but that's nothing, place city hall, then replace houses)
How much are fusion reactors and large mineral extractors going for? And what's the upkeep.
I don't mind what planet we go as-long as we get to use Tat housing :D.
So that Tat/LOk/Dant I personally love Lok and Tat. The right placing near hunting areas on Lok and tat will get a lot of visitors
Cant walk two meters now on Dant as it a credit farming mine. people killing nests leaving mobs.
We need a guild hall don't we for the guild?
I got master Swordsman last night. So I can help out with the resources and guild hall. Small set back last night tho. Failed to repair my armor and had to spend 115k for a new set
If anyone wants some stuff slicing gives us a shout. Great to be back in SWG I've been playing this rather than GW2 which is saying something.
macro stuff
Yeah that's the one I tried and does not work properly :( Just stays on the Assemble page after mats are inserted. Its a known issue though and is in the latest bug fixes on Nova.
I having a working, although by breaking it :), macro so can put up with it for now.
Cool, was just thinking about a smuggler alt won't need one now :) Cheers
It works great, it'll be a miss spelled or similar error that stops it working. Rather than a bug.
No its a bug mate, doesn't trouble all but it is. There's info on the SWGEMU website about it.
http://trac.assembla.com/swgemu/changeset/5754 they just fixed it on the Nova code so hopefully next merge it will be sorted.
If anyone else is having issues I have a workaround.
Think the /nextcraftingstadge does not work for some people. Does not work for me.
If you're spelling it the same as you have above there's your problem.
Should be /nextcraftingstage minus the d I reckon.
Made meself a Brawler over the weekend named Melixx, hope to get some game time this week but may not be able. Would appreciate a mail invite from the OcUK guild if there's one going, cheers!
Hope to see some of you guys ingame :)
Guys I need some help, I chucked my copy of SWG away in disgust a long long time ago in an previous address not so far far away and cant locate another... I have downloaded the 14 day trial to use for the EMU but noted they will ban accounts for using the trial...
Does anyone know where I can get a copy or of a work around for getting on to the emu, I'd love to get playing SWG again, like so many of you it was my first mmo love and I've never felt that way since
Needs a Capital S and playing around with pauses helps fix. It might be a bug, but anyone can get crafting working. I had to add the end pause of 1 second in. You can tell what you need to play about with, depending where it stops. Something's are case sensitive something's aren't. Some stages needs to wait for other things to finish before carrying on so you may need extra/longer pauses.
On a separate note, server up for over 30hours, that has to be a first. But came back to 28k copper, so not complaining.
Just my bad typing on my phone
Any client will work, even the trial.
Yeah I know the trial will work but I have seen on the EMU website that they ban accounts that use the free trial instead of a full copy of the game!
as fsr as I know the game files are identical so it's not like they can really tell. If you're worried then don't use the trial... find the full client!
Trying to get the trial installed at the moment - but nothing seems to be happening when I run the 1.8gig exe.
Does it just take ages to load due to large file or was it really quick foreveryone else?
EDIT - nevermind, just took ages to get going! - installing now :)
Woot construction lvl 1 done, need construction lvl 3 to make city hall.
Found some good resource sampling areas which helps. Also unlocks gungan head statu, where I get 5k do per statue. Takes 3k resources each though, but as long as these good sampling sites don't disappear, shouldn't take more than a day or two.
Just started... just questions
Do you have to spend the 100cr to clone yourself in the tutorial?
I choose marksman but had to learn brawler?
I didnt start with any equipment?
You don't have to clone yourself or insure your items in the tutorial.
I'm pretty sure you don't have to learn Brawler, you can just go to the next corridor.
You should get a pistol, carbine and rifle from the tutorial, did you look in the container in the second room? I think you should get a weapon there and also one/two when you speak to the Imperial guard before going through to face the bandit dude. They're very cheap so just do some noob missions unarmed to get them if you want them.
