Caporegime
- 18 Sep 2009
- Dormanstown.
That'd make it around 25 quid, not 15-20.
Thought it was ment tobe £15-20
Say i got the upgrade version of windows 8, does that mean each time i want to do a fresh install i need to install Windows 7 first and then 8 after? Not that i would do this much, if not ever. Iv never bought a upgrade version before, so dunno how it works.
Basically all that has changed is the start, so instead of having the old start menu, you have a full screen start menu (metro) now and tobe honest it isnt too bad once you ve got all the shortcuts you need in the metro.
Its taken me 4 attempts to get the hang of win8, and I cant believe Im going to say this but....... The new start menu(metro) may actually be better as you get 2 menus, your customize menu and a menu with everything.
That's a good question. I am really asking that one myself. However if there are to be no 'full' versions then the one I accidentally found on my memory stick this morning must be an upgrade version. It installed fine on my laptop which was wiped before the install. I think the 'upgrade' isn't the same sort of thing as past versions.
In any event, I am going to have to do a full install as it won't upgrade the machine if the profiles are on a separate disk as mine are to same space in the SSD main drive.
you could make a drive image of your first install, or just reset win 8
The layout of my Start..... Its pretty good as you can get rid of all the other stuff, but you can get the other stuff back if you ever need it by searching or showing all apps.
I'd be very interested if this stuff is backed up to teh cloud. I didn't think it was but what do I know? It would be handy.
Personalisations like start page layout are synchronised to the cloud and replicated to any other machines using the same account (if you want it to)Indeed as I imagine we will all spend a lot of time tweaking our settings and be annoyed if were not in the cloud, but will not matter too much, as I will go the ImageX route when its released.
Build and setup the machine to how I want, imagex to bootable stick.
Kimbie
Oh cool didn't know about the ability to set your own baseline.
That will come in handy
CHeers
It's an amazing feature. I love built in stuff. Long gone are the days of fiddling. I just want to install and go.
