Of course it can, don't be silly.
First off what are your thoughts about time travel?
The parodox...
You travel back in time before you were born and meet your mother, you then kill her,
What happens next? Do you cease to exist at the very moment you kill your mother? and if so then wouldn't your mother be unable to give birth to you in the first place making it impossible for you to travel back in time to kill her?
Of course travelling into the future is possible if we could reach speeds near to the speed of light or faster. What are your thoughts on ecxeeding the speed of light or even bending space (worm hole) for instantaneous travel?
And no I aint mad...YET.![]()
The Vulcan Science Directorate has determined that time travel is impossible.
If time travel was possible, someone would have travelled back and told us by now![]()
edit: @ above. If time travel truly were possible, to say it hasn't been invented yet in the future makes no sense. As there would be an infinite number of points in time where the future is. Everything that will happen for our entire future, will have already happened in some point in the future. Therefore a time machine would 'already' in the future have been invented if it were possible.
The speed of light can't be broken though.
Not necessarily
Most time-travel hypotheses predict that time travel would only be possible back until the "time machine" used for travel was first activated (watch Primer, for example). So, because we have not yet built a working time-machine, we cannot expect to meet time travelers. Once we build the first time-machine, all bets are off![]()
I won't claim to be an expert in the field, I know sod all in it. What is the basis for not being able to travel back in time to before the invention of the machine? Would you need a 'portal' to exit and said portal would be another time machine, and therefore you cannot travel to before the time machines invention as no such 'exit portal' exists in that time?
That's the only way (from what I know, and logically) that that belief seems possible.
So you've got your early days "time machine", you sit on it, it's got cogs, all very steam punk. Importantly, the machine goes with you, so you need to have built it to get there and back.
Then you've got your new age "time machine", so very DeLorean. Many argue that this wasn't better than the original machine mainly due to the rarity of flux capacitors, but white haired gull wing door fans are adamant this is the best method.
Then you've got your "space-time tear gun". Warping the fabric of space allows you to effectively jump into a different time. Although you do run the risk of jumping into and/or creating a different space tangent, effectively isolating any causality issues for your original space-time continuum, making this the preferred method for the causality conscious of modern day time tourists.
If you have something travelling at the speed of light, and you have something with in that object move forwards. Then that would essentially be travelling faster than light.
Saw it on a TV program about Stephen hawking theories![]()
