Give OcUK £249.98 and in return you get the best peripheral EVER!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
The new amazing keyboard from MadCatz/Saitek is available to pre-order at Overclockers. With stock expected to land in September, it is also likely to be quite limited for the first few months.
Saitek Cyborg Strike 7 Gaming Keyboard with Touchscreen LCD Screen @ £249.98 inc VAT
nonl2br
<center><iframe width="560" height="315" src="
" frameborder="0" allowfullscreen></iframe></center><br><br>When a fraction of a second is all that divides victory from defeat, you must be in absolute harmony with your gaming setup. Every command and key location must be committed to muscle memory as there's no time to look away from the screen. Enter the S.T.R.I.K.E. 7 from Mad Catz, the perfect keyboard with which to construct your ideal gaming environment. Whether your game of choice is an RPG, FPS, MMO, RTS, MOBA or any other genre, you can now customize your keyboard's physical arrangement to meet your needs.<br>
Boasting a robust, full metal chassis which is much stronger than most gaming keyboards, the modular design gives you the freedom to interlock only the components which matter most to you and your gaming style. Replete with a specially engineered membrane which mimics the tactile feel generated by the mechanical keys often preferred by gamers - - without the resultant excessive noise - - the S.T.R.I.K.E. 7 Gaming Keyboard provides a distinct competitive edge.<br><br>
Fully Modular for Unparalleled Customization<br>
Borrowing modifiable technology from the world's most adjustable mouse - - the award-winning R.A.T. - - the S.T.R.I.K.E. 7 Gaming Keyboard's unique design provides unprecedented customization options to enhance overall comfort. Armed with total control of your keyboard's fit, size, color, sound, and programming, you can finally play your favorite games exactly as intended: How you like to play them!<br><br>
1. Control Module with V.E.N.O.M. TFT-LCD Touchscreen<br>
Easily navigate the keyboard's many functions with the Control Module's intuitive V.E.N.O.M. touchscreen. Program advanced macros, adjust backlighting, and take in-game control of external functions - - balance game and chat volumes, launch apps and websites, even initiate and control TeamSpeak - - all with a few simple finger taps.
<br><br>
2. Main Keyboard<br>
Thanks to a much smaller footprint than run-of-the-mill keyboards, the main keyboard gives your mouse plenty of extra space for large, sweeping movements. Replacement, interchangeable WASD and cursor keys adapt to your gaming style by giving you the choice of standard, contoured or rubber-edged versions. Full RGB backlighting - - with 16 million color variants - - matches the keyboard to your gaming rig and the keys' laser-etched, lacquered light guides are ideal for gaming in dim environments.
<br><br>
3. Function Strip<br>
Adding four programmable macro buttons to the mix, the removable Function Strip brings the total to 24. Including the V.E.N.O.M. touchscreen, the S.T.R.I.K.E. 7 Gaming Keyboard incorporates 24 programmable macro buttons over three modes to create 72 user-definable commands.
<br><br>
4. NumPad<br>
Just like the Control Module, the NumPad is capable of loose or fix-mounted positioning. The custom connection scheme makes it all possible, and the included set of longer wires bolsters your arrangement options.
<br>
5. 3-Part Active Palm Rest and Two Wrist Rests A height-adjustable, active palm-rest houses both a thumb wheel and an action button for even more controls at your fingertips. Both wrist rests utilize a rugged 5-pin connector to attach to the main keyboard module and NumPad, effectively enhancing your comfort during stints of extended gaming.<br><br>
Uncomplicated Macro Programming<br>
An intuitive graphical interface vastly simplifies the formerly tedious task of macro programming. Assign single or multiple keystrokes, complete with custom timings, to macro keys or interface icons and then easily fine-tune your settings. This ability is essential for fast-paced games which require clear but complex multi-key actions.<br>
Each of the keyboard's three different modes can store your programmed macros; you need only switch to a different mode mid-game to triple your available commands. Once programmed, custom profiles can be published to share with your community and saved for later recall, allowing for a seamless transition to another gaming PC.<br><br>
Integrated TeamSpeak Functionality with Visual Identifier<br>
The team at Mad Catz collaborated with TeamSpeak's development team to integrate their state-of-the-art chat technology into the S.T.R.I.K.E. 7 Gaming Keyboard. Once you have the TeamSpeak application running on the keyboard's V.E.N.O.M. touchscreen, select specific game rooms to check who is online and who is actively talking. You can even control the chat volume from within the game you are playing, removing the need to pause and switch programs.
Only £249.98 inc VAT.
ORDER NOW
DAMN !!!
In my defence I was only beaten as some Doris knocked on my door to read my meter. :mad: + :D
I want it because its full of buttons and it moves like a transformer lol.
But for the price, ill stick to saving for my GFX card ;)
It's the touchscreen display that bumps up the price in this occasion.
I understand that. I think they could've at least done a partial mechanical job though like some other keyboards on the market. Even if it was just the WASD keys it'd feel more like a premium gaming product.
My eyes!!!! my eyes!!!
Damn that's hideous.
The touch screen thing as a gaming aid is completely pointless as well. The whole point of a keyboard is that it gives you feedback with out the need to look at what your touching.
A gamer is going to have to look down from their screen to use the touch screen setup. Redundant.
This is more about adding gimmicks than actually adding usable gaming functionality.
The only use for the touch screen bit is if it can be used as a media remote, which oddly enough, it looks like is the one thing it CANT do.
Oh lawd.
I've never found a keyboard that was improved by adding anything more than media buttons quite frankly.
Boy is it ugly.
Looks interesting wonder how the touchscreen will work i.e. can it be programmed with buttons a bit like the Razer SWTOR keyboard or the new Razer DeathStalker Ultimate (which is $249) and has the built in screen and oled buttons
