Sleeping Dogs
I really didn't expect this game to be as great as it is. Will definitely be hooked on it :)
Couple of annoying things though, im getting a lot of stuttering despite no drops in fps and I don't like the little shakes that happen when driving, its very odd looking.
Graphically its stunning imo, very impressed.
Loving this, the martial arts challenges are great. It's hard not to button mash a bit but once you stop and plan your attacks it's really rewarding.
Can't believe how stunning this game is, especially when it's raining!
piccy
Hmmm I seem to suck at combat :( keep getting owned, any tips? Maybe I just need more practice with the 360 controller.
Best advice is to get health upgrades via shrines and keep upgrading character moves it becomes much more easy longer you play.
You will probably die a lot at start just keep at it and should get hang of it.
Spent a good 8 hours on this now and completely hooked. The combat just doesn't get boring! The odd camera shaking (and perhaps the camera control in general) whilst driving is literally my only complaint.
Don't button bash, if you do you'll struggle to get counters in. Learn which types of enemy are vulnerable to what and move around to keep from getting surrounded.
Display settings wont change?
Anyone solved this issue?
In options when i change display settings it wont save just reverts back to how it was.
Will I need to wait for new patch for fix...?
Yeah ive been getting that very annoying, what i did was, do my settings then did a benchmark with them and it all seemed fine
An update has gone live on Steam:
Sleeping Dogs 1.4 Update
Bug Fixes
• Several bugs with the Display Options screen resetting options when backing out of the Advanced Options Menu.
• Tuned the difficulty of the Lock Pick Mini-game for Mouse and Keyboard.
Enjoy!
sigh ffs the graphics settings are still ******
your game should have auto updated if you had steam running , when you launch the game you should get the message about steam configuring the game or whatever it says, thats how you know it patched
yep still display options same problem reverts back all time wtf :(
