Connection speeds?!
20 Apr 2008
West Midlands
i had my 100mb virgin connected on thursday. couple of speed tests returned the correct values.
However i've now run several tests via speedtest and i get conflicting result and am wondering why.
Basically wirelessly via my mac i see between 50 & 60mbps. not bad for wireless.
Via ethernet (direct from router) into mac i get between 90 & 105mb. great!
Yet on my PC (via powerline) i only see a maximum of 65mbps!.
is this because my powerlines have a connection of 10/100 ports and not gigabit ports?
Never used powerline adapters personally, but it is obvious to see that the powerlines are causing the issue. Could be down to old wiring (electrics), not as good quality adapters, etc..
im having same problemim getting 60mbps wired directly in but powerline to pc upstairs is only getting 35mbps.
Are you using a 200mbps powerline kit?
Do you really need 100mb on all devices ?
ive got 100mb connection and only get 45mb upstairs but that suits me fine.
with powerline adaptors.
