You can call it whatever you like to suit: fanboy, bandwagon etc. the driver caused an issue he has resolved it by rolling back. Discussion over. Stop trying to generate friction from some lingering grievance you hold. It's a little odd.
Which is the same logic as the newer Prime95's failing where the old ones would not when it came to over clocking, rollback to the older versions because they pass my overclocks.
Its not establishing where the issue really is, its avoiding it.
Its up to he OP what he wants to do, im just offering him up other possibilities which you are not because just blame the AMD driver first and foremost is your favourite.
