- 20 Apr 2004
- Rugby
GTX 480 SLI
GPU1 63.1%
GPU3 73.8%
GPU1 63.1%
GPU3 73.8%
There's already a thread for this: * * * POST Your GPU ASIC Quality Thread
So there is, the last post was made 6 months ago, do delete this thread, reply and bump it?
I've requested that your thread be merged with the other thread so it should sort itself out.
Edit:
Sorted![]()
EVGA GTX 570 Superclocked
51.4%
Is that gash? I am uisng some pretty old drivers, does this make any difference?
The numbers seem a bit meaningless but trend I've seen - which actually seems slightly different to what the GPU-Z author suggested:
Cards with low number <=60% seem to run fairly hot but overclock well, respond better to enhanced cooling than they do higher voltages.
Cards with >60% don't seem to overclock as well on stock but respond better to extra voltage and get good results when watercooled and a voltage boost.
thanks surveyor. So in theory my 570 should be a good clocker but bad for taking more voltage?
Ill test this theory out tonight as I have never overclocked it.
Means nothing, 74%, 71% and 82% for each of my cards, the one that is 74% out clocks the other two by nearly 100mhz.
+1
Heres mine and for ocing their not good.
88.6%
90.5%
91.1%
86.5%
+1
88.6%
90.5%
91.1%
86.5%
