**AMD REALLY KICK ASS: HOT DEALS ON 7800 & 7900 SERIES FROM OcUK!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Check out some of these pretty epic AMD VGA deals:-
MSI HD 7970 3072MB GDDR5 PCI-Express Graphics Card @ £299.99 inc VAT
As AMD is going to launch its latest HD 7000 series GPU on Jan. 9th, 2012, MSI also will release R7970-2PMD3GD5 graphics card at the same time. MSI R7970-2PMD3GD5 has exclusive GPU Overvoltage support through MSI's Afterburner utility allowing amazing overclocked performance from the get-go. Equipped with 3GB GDDR5 memory allows for the unprecedented memory bandwidth levels needed to run today visually hottest DirectX 11 titles at extreme resolutions across multiple displays. Stability is guaranteed through the use of All Solid Capacitors making sure the R7970-2PMD3GD5 and R7950-2PMD3GD5 have an ultra-long lifespan even under the stress of continuous gaming. DisplayPort 1.2 and HDMI 1.4a connectors allows all new audio and video formats like Blu-ray 3D Stereo, "Deep Color" (for true natural color representation) and 7.1 High Bitrate audio to be presented on up-to six displays through AMD's Eyefinity Technology.
MSI's R7900 series graphics cards are the first graphics cards in the world to support the new PCI Express Gen 3 format. With a processor and mainboard that has PCI Express Gen 3 capability, users will be able to enjoy maximized gaming performance via the ultra-high 32GB/S bandwidth. The R7900 series graphics cards have also adopted the brand new AMD 28nm graphics chip to provide higher performance computing compared to previous generation 40nm products.
MSI's R7970-2PMD3GD5 graphics cards are equipped with the popular Afterburner tuning software, allowing users to adjust the core voltage and improve overclocking potential. In addition, Afterburner also features bundled Predator in-game video capture, remote monitoring capabilities via mobile phone, as well as Kombustor GPU stress testing and other amazing features at no extra charge, providing an exceptional software suite for users of the HD 7000 series graphics cards.
MSI's R7900 series graphics cards support AMD's exclusive Eyefinity multi-monitor display technology. The expanded field of view is perfect for professionals and hardcore gamers. The new MSI R7900 series cards support next-generation Display Port 1.2 and HDMI 1.4a interfaces with stereoscopic 3D capability, as well as 7.1 channel lossless high quality TrueHD and DTS-HD audio formats, providing users with the best audio and visual experience possible.
MSI's R7970-2PMD3GD5 has adopted all solid capacitors. The aluminum core is capable of maintaining a high degree of stability even when working under full loads over extended periods of time. With a 10-year lifespan, MSI rids users of concerns over potential crashes or delays that are caused by system hardware overheating, further providing users with the best computing experience possible.
Features:-
- Fastest single GPU graphics card on the planet
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 925MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5500MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 6-pin
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- 3yr Warranty
Was [£319.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
MSI HD 7970 OC 3072MB GDDR5 PCI-Express Graphics Card @ £319.99 inc VAT
Features:-
- Core Clock Speed: 1010MHz
- 3yr Warranty
Was [£359.99] Inc. VAT
Only £319.99 inc VAT.
ORDER NOW
VTX3D HD 7950 X-Edition 3072MB GDDR5 PCI-Express Graphics Card @ £227.99 inc VAT
VTX3D HD7950 X Edition incorporates the latest PCI-E Gen 3 to get the maximum performance from your GPU. Both fitted with 3GB of GDDR5 memory connected via a new high speed 384 bit memory interface. VTX3D HD7950 X Edition is clocked at 880MHz, also together with 5000Mhz for memory, fulfilling those who thirst for extreme performance. The HD7970 X Edition also features ultra cooling design. With two 92mm ultra big fan and SSU-shape heat pipe design, this efficient cooling solution maximizes the speed of heat dissipation, but minimizes the noisy level, creating most pleasing environment for gaming.
The World's first 28nm GPU. The revolutionary new GCN Architecture. Ready for DirectX 11.1. PCI Express 3.0. The AMD Radeon™ HD 7950 is your personal checklist for ground-breaking technology. The next generation of AMD Eyefinity technology is here, featuring all-new support for stereo 3D, universal bezel compensation and brand new display configurations. Face it: the best just got better. Armed with the new PCI Express 3.0 standard, multi-GPU configurations with AMD CrossFire™ technology are just another way to obliterate the competition with the revolutionary AMD Radeon™ HD 7950. Leave no performance behind. Get higher clocks and faster gaming with AMD PowerTune technology on AMD Radeon™ HD 7950 Graphics. Fold and mine faster than ever with AMD App Acceleration powered by the unprecedented 28nm GCN Architecture. The market isn't ready for 4K video, but Radeon™ is. With full support for 3GHz HDMI 1.4a and DisplayPort 1.2 HBR2, the AMD Radeon™ HD 7950 is set for Quad HD.
- Core Clock: 880MHz
- Memory: 3072MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 1792
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 2 Years
Was [£239.99] Inc. VAT
Only £227.99 inc VAT.
ORDER NOW
MSI HD 7870 Hawk 2048MB GDDR5 PCI-Express Graphics Card w/ Nexuiz & Dirt Showdown PC Games @ £199.99 inc VAT
MSI R7870 Hawk, equipped with AMD's 28nm Radeon HD 7870 GPU. MSI introduce the flagship design concept of Lightning series into R7870 Hawk, adopting UnlockedDigitalPower that incorporates an Unlocked BIOS, DigitalPWM Controller, and Enhanced Power Design to boost overclocking potential and make overclocking easier than ever. With the industry first "GPU Reactor" power panel, it reduces power supply noise as well as increases overclocking stability. As for thermal solution, MSI R7870 Hawk utilizes the latest Twin Frozr IV Thermal Design with Dust Removal Technology. The dual 8cm fan setup with PropellerBlade Technology generate massive airflow for fast heat dissipation while remaining whisper silent. The two form-in-one heatsinks improve cooling for memory and the power module as well ensure structural integrity. The R7870 Hawk uses Military Class III components which have passed rigorous testing to meet MILSTD810G standards, guaranteeing the card's stability and reliability under actual use conditions. Moreover, the "3X3 OC Kits" are designed to simplify overclocking, which makes it easier for users to fine-tune their graphics cards. Competing with flagship design of Lightning series, R7870 Hawk absolutely stands out on top among the industry's HD 7870 based graphics cards.
The MSI R7870 Hawk implements the innovative "GPU Reactor" power panel which, when installed on the back of the GPU, increases current volume by 5 times, reduces power supply noise by 20%, and improves the overall GPU overclocking stability. MSI GPU Reactor is easy to install and has built in safety features that make it easy even for ordinary users to install and remove.
MSI exclusive Unlocked DigitalPower is composed of the Unlocked BIOS, DigitalPWM Controller, and Enhanced Power Design. Unlocked BIOS gives you an increased PowerTune limit (up 57%) as well as more relaxed AMD Catalyst Control Center and OverCurrent Protection limits which means access to the MSI R7870 Hawk full overclocking potential. The DigitalPWM Controller provides more stable and accurate voltage signals than analog designs, meaning the voltage can be adjusted more quickly and precisely during overclocking. Enhanced Power Design provides more power than the reference design. Equipped with Unlocked DigitalPower, the MSI R7870 Hawk is the best tool for gamers.
The MSI R7870 Hawk incorporates the next-generation Twin Frozr IV Thermal Design. The striking design of the new Twin Frozr IV comes from the two 8cm PWM fan setup with PropellerBlade Technology and two 8mm SuperPipes to enhance heat dissipation. MSI has also incorporated its exclusive Dust Removal Technology in the Twin Frozr IV enhancing the Thermal performance over a long lifespan because at every boot, the fan will reverse for 30 seconds when booting to remove dust from heat sinks. The two form-in-one heat sinks cool the memory and power modules, ensure the structural integrity and card is protected from any accidental dents or scratches. The Twin Frozr IV on MSI's R7870 Hawk is 15? cooler and 5.7dB quieter than the reference design.
Features:-
- Core Clock: 1100MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Processing Cores: 1280
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI Avivo HD
- Warranty: 3 Years
- Supplied with Nexuiz & Dirt Showdown PC Games
Was [£219.95] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
MSI HD 7850 Power Edition Twin Frozr IV OC 2048MB GDDR5 PCI-Express Graphics Card w/ Nexuiz & Dirt Showdown PC Games @ £167.99 inc VAT
nonl2br
<img src="http://marketing-uk.msi.com/images/7000PowerEdition.jpg" alt="Power Edition" /><br>
<br>
<Font size="4"><b>Key Features</b></font><br>
<br>
<b>Power Edition Architecture</b><br>
- Triple Overvoltage: Adjustable GPU, Memory and VDDCI via Afterburner to unleash the potential of the graphics card<br>
- Enhanced PWM Design: more phases provide higher overclocking capability and better stability at peak load<br>
<br>
<b>Twin Frozr IV cooler with Dust Removal technology</b><br>
- Provides 22°C Cooler and 11dB quieter operation than reference product<br>
- cooler removes dust build up every time it is switched on to keep cooling performance optimal<br>
<br>
<b>Military Class III Components</b><br>
- Components meet US Military Standard MIL-STD-810G to ensure the best stability and quality<br>
- Hi-C Caps, SFC and Solid caps are the most reliable and efficient components available<br>
<br>
<b>MSI Afterburner Overclocking Utility</b><br>
- MSI's exclusive overclocking software<br>
- Built-in Kombustor stability test software<br>
- Built-in real-time video capture software<br>
<br>
<Font size="4"><b>Specifications</b></font><br>
<b>Graphics Engine</b> ATI Radeon HD 7850 <br>
<b>Interface</b> PCI Express x16 3.0 <br>
<b>Memory Type</b> GDDR5 <br>
<b>Memory Size(MB)</b> 2048 <br>
<b>Memory Interface</b> 256 bits <br>
<b>Core Clock Speed(MHz)</b> 950 <br>
<b>Memory Clock Speed(MHz)</b> 4800 <br>
<b>DVI Output</b> 1 <br>
<b>HDMI-Output</b> 1 <br>
<b>Mini DisplayPort</b> 2 <br>
<b>HDCP Support</b> Y <br>
<b>HDMI Support</b> Y <br>
<b>Dual-link DVI</b> Y <br>
<b>Display Output (Max Resolution)</b> 2560x1600 <br>
<b>RAMDACs</b> 400 <br>
<b>DirectX Version Support</b> 11 <br>
<b>OpenGL Version Support</b> 4.2 <br>
<b>CrossFire Support</b> Y <br>
<b>Warranty</b>3 Years<br>
<b>Product Review:</b> http://tbreak.com/tech/2012/05/msi-r7850-power-edition-review/ <br>
Was [£179.99] Inc. VAT
Only £167.99 inc VAT.
ORDER NOW
MSI HD 7850 Twin Frozr III OC 2048MB GDDR5 PCI-Express Graphics Cards w/ Nexuiz & Dirt Showdown PC Games @ £159.98 inc VAT
nonl2br<Font size="4"><b>Key Features</b></font><br>
<br>
<b>Propeller Blade on Twin Frozr III</b><br>
- The special blade design generates 20% more airflow than traditional design.<br>
- 10C cooler & 13.7dB quieter than reference design!!!<br>
<br>
<b>MSI Afterburner overclocking utility</b><br>
- Supports overvoltage function<br>
- Supports advanced fan speed control.<br>
- Supports burn-in stability test. <br>
<br>
<b>All Solid Capacitors</b><br>
- 10 years ultra-long lifespan<br>
- Lower Temperature and Higher Efficiency<br>
<br>
<b>AMD Eyefinity Technology Support</b><br>
- AMD Eyefinity Technology supports maximum 6 displays with 2 DisplayPorts via Multi-Stream Transport (MST HUB).<br>
<br>
<b>Core Clock Speed(MHz)</b> 900 <br>
<b>Card Dimension(mm)</b> 197 x 111 x 38mm <br>
<b>Warranty</b> 3 Years<br>
Was [£169.99] Inc. VAT
Only £159.98 inc VAT.
ORDER NOW
Sapphire HD 7850 2048MB GDDR5 PCI-Express Graphics Card w/ Nexuiz & Dirt Showdown PC Games @ £155.99 inc VAT
Offering excellent performance at an even keener price, SAPPHIRE HD 7850 shares the features of the HD 7000 family with Dual-X cooling technology, a highly efficient multi-heatpipe cooler with dual fans providing quiet and very cool operation during normal operating conditions, and superb cooling performance even under extreme load.
Features:-
- Core Clock: 860MHz
- Processing Cores: 1024
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was [£164.99] Inc. VAT
Only £155.99 inc VAT.
ORDER NOW
Our prices are crazy and more stock incoming on the lines which will no doubt run out! :D :D
I use to work in a bakery and we use to sell hot cakes, but they didn't sell anything like AMD cards!
I am assuming the 7970 MSI OC cards are using binned chips ?
Extremely unlikely. Just a factory o/c.
If msi were binning chips they would save them for twin frozr / power edition / hawk / lightning, in that order. nd probably only the lightnings.
That's if, lol.
AMD's price move, has made them sell like hot cakes, infact many of our lines are looking to sell out. :eek:
so this is amd's decision to drop prices ? just wondering if this will stay liek this for the tiem being as i'm already tempted and not long had my 6850
Possibly, they are overclocked by default to 1040 core so i guess the percentages of getting a better clocker might be slightly higher.
Mine will do 1200core @1.175 (stock 1.112) and 1250core @1.2.
