- 2 May 2011
- Woking
Evening all,
I'm having a rather horrendous problem. I was attempting to use Clonezilla to put a larger disc onto a smaller one and tried to change the HD size with Gparted. This kind of worked but I got a bit fed up and decided to reinstall Windows 7.
Now, I couldn't get the installation to work on the correct HD. When in the Windows 7 installation screen that allows you to select which to install to, I deleted some of the drives and I think it's caused some sort of problem. I ended up installing Windows on an SSD as I had planned, but now my other HDs no longer appear to exist to both the BIOS and to Windows...please help!!!
Thanks in advance,
dirtychinchilla
Thanks in advance,
dirtychinchilla
